Gel Stain from General Finishes is home of the popular Java Gel Stain featured across the nation's social media for upcycling furniture and cabinets.
All stains need a top coat. Think of stain as the color and top coat as the sealer and protectant.
The high urethane content of General Finishes Gel Stains results in a lustrous finish that tends to fool people into assuming no sealant is required. The beauty of Gel Stain comes from thick thick urethane which can carry a LOT of color to any surface, but that color must be sealed in with top coat. An added bonus of top coat is that it also protects the wood from drying out.
You can apply Gel Stain to MDF, stained surfaces
Melissa Harvey used General Finishes Java Gel Stain<
It's a wrap! General Finishes next round of tutorial videos are on their way! We will be releasing one per week for the month of November so stay tuned.
Yes, you can mix similar products together at any ratio to make more color options.
You can also mix with 10% General Finishes Liquid Oil Based Wood Penetrating Stains to obtain a slightly thinner stain than the normal Gel Stain formula.
Heidi Martin used General Finishes Java Gel Stain
