Flat Out Flat Water Based Top Coat
Flat Out Flat is a self-crosslinking water-based topcoat that mimics the lustrous look and feel of wax. The increased matting agents used to create "flat look" cause this wood finish to have less clarity, show fingerprints more and provide slightly less durability than High Performance. It is recommended for medium to low-use surfaces other than kitchen cabinets and table tops.
Watch product overview video here. Need some inspiration? Visit the General Finishes Design Center or Pinterest Board for furniture topcoat ideas.
The referenced media source is missing and needs to be re-embedded.
General Finishes Water Based Topcoat Flat Out Flat, Quart
Raw wood
New Stained Surface: Do not sand. Apply directly to the stained surface.
Pre-Finished Wood & Sealed Surfaces
  2. Dry 1-2 hours.
  4. Remove Dust
Other Substrates: Interior MDF, HDF, & Masonite
Can be used with proper preparation & priming. Always test first.
Step 2: How To Apply General Finishes Flat Out Flat
CAUTION: Do NOT use GF Flat Out Flat or any other clear coat, over white or light paints such as GF Milk Paint, or GF White Poly as it may cause yellowing. Any clear coat can become reactive over wood substrates or existing finishes causing tannin, stain or dye bleed-through. All of GF's White Paints, brushable or spray versions, do NOT require a topcoat.
General Finishes Flat Out Flat Application Steps
  1. Watch Flat Out Flat product overview video here.
  3. Stir topcoat thoroughly to reincorporate solids that have settled to the bottom of the can before and throughout the application process. Do not shake.
  4. Test for adhesion when applying over an existing finish.
  5. Thin as desired with distilled water; start with 5%, adding up to 10% by volume.
  6. Increase open time, if needed, with 10-15% General Finishes Extender  if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the products non-compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
  7. Apply 3 coats. No more than three coats is recommended. Additional coats will not improve durability. Flat Out Flat contains more matting agents to decrease the sheen, and the finish can get cloudy when excessive topcoats are applied.
    • Hand application: Apply a liberal amount using a synthetic bristle brush, foam brush, pad applicator or roller with smooth, even strokes & light lap lines.  Avoid heavy pressure and back-brushing. Lap lines will tighten down as they dry.
    • Spray application: Before spraying, strain topcoat through a fine-mesh filter. Spray wet films at 3-5-mil thickness. HVLP: 1.1mm-1.3mm spray tip, medium air cap. Verify tip sizes with your equipment supplier. See our general guide for spray tip sizes. Keep your gun at a 90° angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 25% to conceal lines. Wear a full filter respirator (NIOSH/MSHA approved) and work in a ventilated space. Visit this FAQ for more information on spraying techniques.
  8. If a faster build is desired over raw wood, use General Finishes Sanding Sealer for the first coat, followed by 2 coats of Flat Out Flat.
  9. Finish sand between coats with a fine-grade (220-320) foam sanding pad to improve smoothness and adhesion. Do not use conventional steel wool.
  10. Remove dust with a vacuum, oil-free tack cloth or clean water-dampened rag before re-coating.
Tips to prevent streaking during hand-application
See our video: How to Prevent Streaking with Water Based Topcoat
  • To avoid streaking, apply a liberal amount of product and avoid using pressure and back-brushing. Wipe the wood grain using smooth, even strokes. Use a large applicator, such as a paint pad, for larger surfaces.
  • Remove streaks by buffing with or fine-grade (220-320) sanding pad, or sanding well and re-coating.
  • For the smoothest result, apply with a spray gun.
Mixing Topcoats
Do not mix Flat Out Flat and High Performance topcoats. They are engineered with different resin systems.
Use
  • Flat Out flat is not recommended for high-use areas such as cabinets and tabletops. The popular flat sheens are lovely, but they have different properties than glossy finishes. The flatting agents required to reduce sheen in matte topcoats also slightly reduce clarity, water resistance, durability and resistance to chemicals such as ketchup, soap, chemical cleaners or ammonia. This is not much of a concern in low-use areas but is important for tabletops or kitchen cabinets.
  • Here is a tip to improve the performance of your finish and still obtain a matte sheen: Use a semi-gloss sheen for the first 2 coats and a flat for the third for optimum performance.
  • Or instead use High Performance Water Based Topcoat or Arm-R-Seal Oil Based Topcoat.
Dry Time based on ideal conditions of 70°F 21°C; 50% humidity.
Dry time: 2+ hours in ideal conditions
Be sure to allow adequate dry time. You can tell if a water-based finish is dry if it forms a powder when lightly sanded with a fine-grade (220-320) foam sanding pad or 400-grit sandpaper. If in doubt, wait longer. Rushing the dry time can cause "blush," which is clouding in the finish due to moisture trapped between the layers.
  • Temperatures are cooler.
Yellowing & Clear Topcoat
There is no reliable way to predict whether yellowing will occur and to what degree. Every existing finish is different and we rarely know the finishing provenance on an existing piece. Every tree is different and every piece of wood is unique. Raw wood can bleed tannins immediately after the topcoat dries or months later with seasonal temperature changes. Oak, pine, mahogany, and Douglas fir are particularly prone to bleed-through.
Summary
Tips to Prevent Yellowing
  • Use a professional product such as General Finishes Enduro White Poly. It has "increased topcoat properties," is a standalone finish when 3 coats are applied, and does not require sealing with a topcoat.
Knots
Flat Out Flat Topcoat Warnings and Warranties
CAUTION: MAY CAUSE EYE IRRITATION.
Keep out of the reach of children. Avoid contact with eyes. Keep container tightly closed and sealed until ready for use. Wash thoroughly after handling.
Sheen Very Flat (1-5)
Tintable No
Type Self-crosslinking Acrylic
Coverage 65-75 sq.ft./pint, 125-150 sq.ft./quart, 500-600 sq.ft./gallon
Viscosity (cPs) 350-450
Weight Solids 24%
< 250 g/L
Durability (Highest, High, Medium, Low) Low
Hardness (Koenig #) 89
Wear (Taber #) 50.00 mg loss
Water (5 max) 4
Chemical (105 max) 86
Flat Out Flat FAQs
What is the difference between Flat Out Flat and High Performance Topcoats?
Flat Out Flat is a matte water based topcoat with a velvety feel and was developed as a durable alternative to our Satin Wax.
Choose this product if you want a finish that looks more like wax and your project will not require high use. Like wax, it dries softer to the touch than High Performance when completely cured, and it will show more marring and fingerprints. Flat Out Flat is made with a stable self cross-linking acrylic instead of urethane.
High Performance is urethane based and contains less matting agents which result in a slightly harder finish.
For that reason, High Performance is the best choice for high use areas such as table tops and kitchen cabinets. Both topcoats have similar water resistance, but High Performance offers greater clarity. To achieve the matte aesthetic without sacrificing durability or clarity, try High Performance Dead Flat.
Use with Oil Based Finishes: Let oil-based finishes dry for 72 hours before applying High Performance or Flat Out Flat top coat.
*Can I Mix General Finishes Flat Out Flat and High Performance Topcoat?
No, you should not mix Flat Out Flat and High Performance topcoats. They are engineered with different resin systems.
You can mix High Performance topcoats to adjust sheen. For example, you can mix HP Flat and HP gloss to obtain a different sheen.
What is the best way to obtain a more durable finish with a flat sheen?
The popular flat sheens are lovely but they have different attributes than glossy finishes. The flatting agents required to reduce sheen in flat or matte topcoats also slightly reduce clarity, water resistance, durability and resistance to chemicals such as ketchup, soap, chemical cleaners, or ammonia. This is not much of a concern in low use areas but is important for table tops or kitchen cabinets.
Here is a tip to improve the performance of your finish and still obtain a matte sheen: Use a semi-gloss sheen for the first two coats and a flat for the third for optimum performance.
General Finishes is constantly seeking new resins and additives to improve the performance of our finishes.
*How Can I Tell if a Water Based Topcoat is Dry?
*Which Is Better as a Sealer? Topcoat or Wax?
Furthermore, nothing adheres well to wax, which can impact future finish changes. Even though there is internet chatter about removing wax with 3rd party products or mineral spirits, the risk of a failure in re-coating over a wax finish is very high and sometimes impossible.
If you love a wax finish, try General Finishes Satin Finishing Wax. If you want the look and feel of wax with more durability, use our General Finishes Flat Out Flat Topcoat. For even more protection, use General Finishes High Performance Topcoat.
