Sanding Sealer from General Finishes
Sanding Sealer is a water based acrylic basecoat. It provides initial sealing for all water based topcoats and can be used over raw wood or a stained surface.
Sanding Sealer has been sterated so it will sand easier. Sanding Sealer is not as durable as our topcoats so it is not recommended for a final finish.
Need some inspiration? Visit the General Finishes Design Center or Pinterest Board for furniture ideas.
Features
COLOR: Water White
SHEEN: Gloss
SANDING: On bare wood sand to 180 grit (220 grit for more open grained woods). DO NOT sand stains before topcoating.
COATS: 1 or 2
RECOAT: 1-2 hours
CURE TIME: 20 days under ideal conditions (70° and 70% humidity). However, this may vary slightly with humidity & temperature. Good ventilation, air movement and higher temperatures will accelerate dry time.
APPLICATION: Acrylic brush, foam brush, paint pad applicator, or spray
CLEANUP: Soap and warm water
COVERAGE: 150 sq. ft/qtVOC: <228 g/l ( 1.90 lbs/gal)
CAN SIZES: Quart, Gallon
LOW VOC, LOW ODOR
COMPATIBILITY: GF Sanding Sealer self seals and can be used with High Performance, or Enduro Poly topcoats. DO NOT use with Enduro-Var
WARNING: TEST FOR COMPATIBILITY WHEN USING THIS PRODUCT WITH PRODUCTS FROM OTHER BRANDS.
General Finishes products should be tested to your complete satisfaction before using. General Finishes will not be responsible for any failure if our products are used in conjunction with other brands of finishes. We do not test General Finishes products with those of another manufacturer and will not accept liability if there is a compatibility issue.
SDS
Safety Data Sheets
