fbpx White Undercoat for Professional Wood Finishing | General Finishes
Enduro White Undercoat
General Finishes White Undercoat is similar to General Finishes Sanding Sealer with the addition of white colorant to provide a primer undercoat for white/off-white wood finishes. The high solids facilitate a fast film build and sand easily. Use as a basecoat for pigmented acrylic finishes. It dries tack-free in 10-20 minutes. Particularly effective on MDF.
Find A Store Compare Similar Products
General Finishes Enduro White Undercoat, Gallon
All wood projects require preparation sanding, and all existing finishes require prep cleaning and sanding. If you skip this critical step, your finish may fail.
Preparation for Raw Wood
  1. Sanding Schedule: 120-grit followed by 150- or 220-grit sandpaper.
  2. Remove dust with a water-dampened rag or oil-free tack cloth.
  3. Let dry completely before applying GF product.
  4. Do not over-sand with fine-grit sandpapers; this will close and seal the wood grain, preventing ideal color absorption.
  5. Do NOT use steel wool with water-based finishes; the particles will get trapped in the finish and rust.
Preparation for Existing Finishes
See our video: How to Prep Existing Finishes
  1.  Scuff clean with a Scotch-Brite™ pad or maroon synthetic steel wool & 50:50 mix of denatured alcohol & water.
  2. Dry 1-2 hours.
  3. Sand lightly with 220-320-grit foam sanding sponge.
  4.  Remove dust.
Step 2: How To Apply General Finishes Enduro White Undercoat
General Finishes White Undercoat can be applied over raw wood MDF, existing finishes and as an undercoat for White Poly and light-colored paints. It acts as a physical barrier rather than a chemical barrier. For woods that exhibit tannin bleed-through, we recommend General Finishes Stain Blocker
Enduro White Undercoat Application Steps
  1. Stir General Finishes Enduro White Undercoat to reincorporate solids that have settled to the bottom of the can before and throughout the application process.
  2. Thin as desired with distilled water; start with 5%, increase up to 10% by volume. Increase open time, if needed, with up to 5% by volume of General Finishes Extender, if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates.
  3. Apply 1-2 coats, depending on the substrate, the amount applied, and the application method. If you apply 1 light coat you can sand through, add another coat. If you apply 1 solid first coat and sand lightly, then you only need one.
    • Spray application: Before spraying, strain through a medium-mesh filter. Spray wet films at 3-5-mil thickness. Medium air cap. Fluid tip sizes: Compressed air: .040, HVLP: .072 or Airless: .011-.013. medium air cap. Verify tip sizes with your equipment supplier. See our general guide for spray tip sizes. Keep your gun at a 90° angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 25% to conceal lines. Wear a full filter (NIOSH/MSHA approved) respiratory & eye protection and work in a ventilated space. Read here for more information on spraying techniques.
    • Face frames on cabinets: Enduro professional products are engineered to be spray-only but can be applied successfully to cabinet face frames, edges or drawer fronts with a brush, pad or small cabinet specific 3/8" nap microfiber roller such as Whizz or AllPro brand. Larger areas may not level with hand application.
  4. If a faster build is desired over raw wood, use General Finishes Sanding Sealer for the first coat, followed by 2 coats of High Performance Topcoat.
  5. Dry 2+ hours between coats in ideal conditions: 70°F/20°C; 50-70% humidity. Inadequate dry time is one of the top reasons for product failure. You can tell if a water-based finish is dry if it forms a powder when lightly sanded with a fine-grade (220-320) foam sanding pad. If in doubt, wait longer. Increase dry time if:
  6. Finish sand between coats with a fine-grade (220-320) foam sanding pad to improve smoothness and adhesion.
  7. Remove dust with a vacuum, compressed air, an oil-free tack cloth or a water-dampened rag.
  8. Seal White Undercoat with topcoat to equal 4 total coats. If 1 coat of White Undercoat is applied, apply 3 coats topcoat over it. If 2 coats White Undercoat are applied, apply 2 coats topcoat. One coat White Undercoat sealed with 3 coats topcoat is recommended for durability. It's better to have more topcoat than undercoat.
Application tools and materials containing water-based products can be cleaned with soap and water immediately after use.
Storage of Water-Based Products
Please be mindful of the manner in which water-based products are stored and how long they have been in storage. They not a forever product.
Water-based products do not last forever, even when unopened. General Finishes products are best used within 1 year of the manufacture date listed on the can. However, the life of the product may be extended with proper care and storage (see Storage Tips below).
  • As with all fine furniture finishes, avoid using furniture polish, cleaners or dusting sprays that contain silicone, alcohol, ammonia and anything acidic. Exception: We have successfully cleaned with Clorox wipes.
Product Colors White
Type Acrylic Primer
Coats 1 - 2 coats
Application Method Spray
Brushable No
Usable over existing finishes No
Spray Tip Sizes HVLP 1.5mm-1.8mm
Can Sizes Gallons, 5 Gallon pails, 55 Gallon drums
Coverage 450 sq. ft/gal
Viscosity Thick
Viscosity (cPs) 1000-2000
Weight Solids 53%
< 95 g/L
