Winner of Fine Woodworking's "Best Overall Choice Award," High Performance Topcoat was voted as the hardest, most durable consumer polyurethane topcoat. It is so versatile, it can be brushed or sprayed.
Traditionally, flat topcoats were created by adding matting agents to gloss topcoat. These agents decreased the durability of the topcoat and produced a slight haze that reduced the vibrancy of an underlying stain or paint.
Using newly patented polymer resin technology, matting agents are no longer required. Our new Dead Flat topcoats produce a brilliant clear finish while providing significant improvements to chemical, water and mar resistance.
Wood Turner's Finish is a water-oil urethane hybrid for use on wood turnings, bowls and other lathe-turned projects, now made with more than 50% RENEWABLE RESOURCES formulated from sustainable materials that decrease the carbon footprint.
The term for a cloudy, milky appearance in the finish is Blush. There are three causes:
1. The most common reason is an incompatible stain. For example, using a water-based topcoat over an oil-based based stain. When the top coat is applied, the oil in the stain seeps up through the finish and reacts with the acrylic causing a chemical blush.
Flat Out Flat is a self-crosslinking water-based topcoat that mimics the lustrous look and feel of wax. The increased matting agents used to create "flat look" cause this wood finish to have less clarity, show fingerprints more and provide slightly less durability than High Performance.
