Jason of Bedre Woodworking shows off his talent with this giant table redo.
This buffet was updated to a modern sleek look by Kelly of Stylish Patina,stylishpatina.com with General Finishes
Doug Parsons of D A Parsons Construction of Chesapeake, VA constructed a walk in closet and bathroom addition from cherry wood.
Meet "Rockstar", a cleverly designed Blue Buffet finished in Coastal Blue Milk Paint from General Finishes.
