Carrie Seitz used General Finishes Antique Walnut Ge
This project from Daniele of Finding Silver Pennies is an awesome example of the magic GF
General Finishes is happy to announce our November 2016 Retailer of the Month, Vinterest Antiques of Hixson, TN.
In our newest video Chris Adams and Tom Monohan of General Finishes demonstrate how to update your existing cabinets with GF Water Based Wood Stain and Dye Stain with a technique called toning. Toning does not require any messy stripping or sanding.
General Finishes Dye Stain
Some pieces of wood contain a lot of oil and walnut can be finicky.
The oil in the walnut wood may be causing the problem you've described - a longer dry time might have been needed over an oily wood. If the wood does not dry over the next few days then it may be necessary to sand down and start over.
Unfortunately, if the first coat does not dry, the second will never dry.
We love this dropleaf maple table with two chairs refinished in red pepper and antique white
Chuck of CL Phillips Fine Furniture steals the stage for this week's Woodworker Wednesday! His services include reproduction of original and custom traditionally-inspired furniture, and the repair and restoration of antiques.
Yes. All stains need a top coat. Think of stain as the color and top coat as the sealer and protectant. Discover the best topcoat for your gel stain.
