These kitchen cabinet transformations come from Cabinet Refresh. They are based in the Los Angeles area and work almost exclusively with General Finishes products. Their work is top notch! Here are a few examples of their amazing talent.
In our newest video Chris Adams and Tom Monohan of General Finishes demonstrate how to update your existing cabinets with GF Water Based Wood Stain and Dye Stain with a technique called toning. Toning does not require any messy stripping or sanding.
The answer is no, General Finishes Milk Paint does not require sealing, especially for lower use pieces such as a coffee table.
A chic dresser transformation from a heavy piece of furniture sitting in a thrift store to an updated feminine dresser with a modern touch!
We love this step-by-step video by OrganizedClutterbug about how she used General Finishes Gel Stain to refinish her kitchen cabinets! Please note, this video was not created by General Finishes, nor is it our professional recommendation for application method, but it is creative!
You can...we do we do believe that wax can be a beautiful addition to many projects. However, it is best not to use wax in high-use temperature-dependent situations like kitchens or bathrooms.
This response is true of prepping and existing finish on furniture, but kitchen cabinets are more problematic because they are work areas where grease, steam, food splatters and oil from hands are common. Prep is basically degreasing and abrading the surface for better adhesion. Oil or substances on hands really show up on a failed re-finish around doorknobs and hands if the surface is not cleaned thoroughly.
Rev up your brushes and save the date! The 2016 GENERAL FINISHES DESIGN CHALLENGE CONTEST kicks off July 4th, 2016. We will post the link to the contest at that time.
