Enduro Professional Water-Based Pre-Cat Lacquer
General Finishes water-based Enduro Pre-Cat Lacquer clear-drying wood finish uses new technology in the polymer manufacturing process. This unique formula produces a smaller and smoother particle, translating into a big increase in film clarity. The chemical, water, and yellowing resistance are superior to competitors, waterborne or solvent. With high block resistance and stack time at a great price point, this is the perfect coating for professional/industrial finishers and OEM production when fast production time is needed. Learn more about General Finish's entire finishing system of clear and pigmented primers, acrylic and polyurethane clears, pigmented topcoats and water-based stains here: 4 Reasons to Switch to Water-Based Finishes. Spray tip recommendations. Made in the U.S.A. by General Finishes:
General Finishes enduro pre-cat lacquer water based finish
Raw wood
New Stained Surface: Do not sand. Apply directly to the stained surface.
Pre-Finished Wood & Sealed Surfaces
  2. Dry 1-2 hours.
  4. Remove Dust
Other Substrates: Interior MDF, HDF, & Masonite
Can be used with proper preparation & priming. Always test first.
Step 2: How To Apply General Finishes Pre-Cat Lacquer
General Finishes Enduro Pre-Cat Lacquer Application Steps
CAUTION: Do NOT use GF Enduro Pre-Cat Lacquer or any other clear coat, over white or light paints such as GF Milk Paint, or GF White Poly as it may cause yellowing. Any clear coat can become reactive over wood substrates or existing finishes, causing tannin or dye bleed-though regardless of priming. All of GF's white paints do NOT require a topcoat.
Enduro Pre-Cat Lacquer is a hard topcoat engineered for a good price point. If higher durability is needed, use Enduro Clear Poly. See our comparison tool for more information.
Download 2024 Professional Water Based Product Catalog here.
  1. Watch product overview video here and comparison video of our topcoats here.
  3. Stir topcoat thoroughly to reincorporate solids that have settled to the bottom of the can before and throughout the application process. Do not shake.
  4. Test for adhesion when applying over an existing sealed surface.
  5. Thin as desired with distilled water; start with 5%, adding up to 10% by volume.
  6. Increase open timeif needed, with 10-15% by volume General Finishes Extender if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the product non-compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
  7. Ready to spray from container. Apply a minimum of 3 coats.
  8.
    • Spray application: Before spraying, strain topcoat through a fine-mesh filter. Spray wet films at 3-5-mil thickness. Medium air cap. Fluid tip sizes: Compressed air: .040, HVLP: .043-.051 or Airless: .009-.013. Verify tip sizes with your equipment supplier. See our spray tip size recommendations. Keep your gun at a 90° angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 25% to conceal lines. Wear a mask and work in a ventilated space. Read here for more information on spraying techniques.
    • Face frames on cabinets: Enduro professional products are engineered to be spray-only but can be successfully applied to cabinet face frames or edges with a pad or small, cabinet-specific roller such as Whizz Velour brand. Larger areas may not level with a hand application. ALTERNATIVE: Use the same sheen of General Finishes High Performance Topcoat on areas that must be brushed.
  9. If a faster build is desired using clears over raw wood, use General Finishes Sanding Sealer for the first 1-2 coats, followed by 2 coats of Pre-Cat Lacquer.
  10. Finish sand between coats with a fine-grade (220-320) foam sanding pad or 400-grit sandpaper to improve smoothness and adhesion.
  11. Remove dust with a vacuum, compressed air, an oil-free tack cloth or a water-dampened rag.
Tinting & Toning with Pre-Cat Lacquer
When tinting, we recommend using General Finishes Enduro Poly or High Performance Topcoat for tinting instead of Pre-Cat Lacquer because they have higher solids.
When toning, add up to 10% General Finishes Dye Stain, General Finishes Water Based Wood Stain, General Finishes Ready-to-Match (RTM) Stain, or Trans Tints. To deepen the color, add a second coat.
Dry Time Based on ideal conditions of 70°F 21°C; 50% humidity.
To touch: 30+ minutes
Recoat: 1+ hours
Be sure to allow adequate dry time. Dry times are dependent on application method and environmental conditions. You can tell if a water-based finish is dry if it forms a powder when lightly sanded with a fine-grade (220-320) foam sanding pad or 400-grit sandpaper. If in doubt, wait longer. Rushing the dry time can cause "blush," which is clouding in the finish due to moisture trapped between the layers.
  • Temperatures are cooler.
Yellowing & Clear Topcoat
There is no reliable way to predict whether yellowing will occur and to what degree. Every existing finish is different and we rarely know the finishing provenance on an existing piece. Every tree is different and every piece of wood is unique. Raw wood can bleed tannins immediately after the topcoat dries or months later with seasonal temperature changes. Oak, pine, mahogany, and Douglas fir are particularly prone to bleed-through.
Summary
Tips to Prevent Yellowing
  • Use a professional product such as General Finishes Enduro White Poly. It has "increased topcoat properties," is a standalone finish when 3 coats are applied, and does not require sealing with a topcoat.
Knots
Sheen Flat (10 or less), Satin (25-35), Semi-Gloss (50-60), Gloss (80+)
Tintable Yes, but not recommended.
Type Self-crosslinking Acrylic
Application Method Spray
Brushable No
Dry Time - Touch 10+ min.
Dry Time - Recoat 1+ hr
Can Sizes Gallons, 5 Gallon pails
Viscosity (cPs) 350-450
Flat: 26%
Satin: 24%
Semi-Gloss: 24%
Gloss: 24%
Solids by Volume
Flat: 24%
Satin: 23%
Semi-Gloss: 23%
Gloss: 23%
Flat: < 250 g/L
Satin: < 250 g/L
Semi-Gloss: < 250 g/L
Gloss: < 250 g/L
Durability (Highest, High, Medium, Low) Medium
Hardness (Koenig #) 130
Wear (Taber #) 94.20 mg loss
Chemical (105 max) 89
*How Do I Spray Water Based Finishes?
Spray Tip Guidelines from General Finishes
Click the image to download a PDF of this chart
General Finishes water-based products can be sprayed through compressed air, HVLP, airless or C.A.S. units.
DOWNLOAD SPRAY TIP CHART PDF
SURFACE PREPARATION:
All surfaces should be clean and free from dirt and oil and sanded.
Indicated below are instructional videos we have for preparing a surface for a new coat of paint or finish:
PRE SEALING:
  • Milk Paint: 1.8mm-2.0mm
  • Brushable White Enamel 1.8mm-2.0mm
  • Stain Blocker: 1.8mm-2.0mm
  • Pearl Effects: 1.8mm-2.0mm
  • Glaze Effects: 1.8mm-2.0mm
  • High-Performance Topcoat: 1.1mm-1.3mm
  • Flat Out Flat Top Coat: 1.1mm-1.3mm
  • Enduro-Var 1.1mm-1.3mm
  • Water-Based Wood Stain: 1.1mm-1.3mm
  • Water-Based Dye Stain: 1.1mm-1.3mm
  • Exterior 450 Topcoat:1.1mm-1.3mm
  • Exterior 450 Stain: 1.1mm-1.3mm
  • Enduro Sanding Sealer: 1.3-1.4mm
  • Enduro White Poly: 1.3mm-1.5mm
  • Enduro Black Poly: 1.3mm-1.5mm
  • Enduro White Under Coat 1.5mm-1.8mm
  • Enduro Clear Poly: 1.1mm-1.3mm
  • Enduro Pre Cat Lacquer: 1.1mm-1.3mm
  • Enduro Conversion Varnish: 1.1mm-1.3mm
SPRAYING TOPCOATS:
Watch our video how to spray water-based topcoats here.
SPRAYING WATER BASED WOOD STAINS:
How Do General Finishes Water Based Topcoats Differ?
Compare all GF Topcoats Here
Watch Video: Comparison of All GF Water Based Finishes Here
PROFESSIONAL TOPCOATS
ENDURO PRE CAT LACQUER (Spray only)
Looking for hardness, clarity and fast stack time? Pre Cat Lacquer is the choice. Use in applications where there is little risk of chemical contamination issues from substances such as ketchup, soap, chemical cleaners, or ammonia. This is the perfect spray finish for interior doors, casing, moldings, door jambs and furniture that receives light use. When you think about it, interior doors don't take a lot of wear. You might wipe them down or dust them once in a while but that is about it. PreCat Lacquer is a hard finish that provides excellent build and superior clarity at a phenomenal price point. If you are not finishing a surface such as a tabletop where you anticipate chemical contamination during use, why pay for a more expensive finish?
Dries clear.
Watch Pre Cat Lacquer Product Overview Video Here
ENDURO CLEAR POLY (Spray only)
Poly is the go-to cabinet finish. It has all the durability you need at a lower price point than Conversion Varnish. It is similar to High Performance in test measurements for chemical, water and wear resistance, but HP can be brushed and Clear Poly can't - it is already thinned for spraying. Clear Poly has a bit of an edge over High Performance in overall chemical resistance, a 98 rating vs 92.
Dries clear.
Watch Clear Poly product overview video here
ENDURO CONVERSION VARNISH (2K-Spray only)
This is our top of the line. Conversion Varnish is a post catalyzed high solids, two component urethane formulated for professionals who need the highest level of durability and chemical resistance. Varnish will cure the fastest. Requires NCO Catalyst. It is recommended for commercial applications or extremely high-wear surfaces such as countertops and bar tops
Dries clear.
Watch Conversion Varnish Product Overview Video Here
Enduro 2K Clear Poly (Spray Only)
For today's professional, industrial and OEM users, water-based Tintable 2K Clear Polyurethane is formulated to stop your biggest frustrations and provide ultimate durability for interior/exterior use. Key features are easy application, fast film build & production time, excellent adhesion, plus optimum water & chemical resistance.
Dries clear.
Watch 2K Clear Poly Product Overview Video Here
Enduro Pro Series Clear Poly
General Finishes Enduro Pro Series Clear Polyurethane is a single-component, self-cross linking polyurethane/acrylic topcoat designed for fast build with excellent flow and leveling. Priced competitively for the professional and industrial markets, Pro Series Clear is tintable and meets or exceeds KCMA standards. Recommended use is interior cabinets, trim, doors, and furniture. Use over raw, stained, or primed wood substrates.
Dries clear.
RETAIL TOPCOATS
HIGH PERFORMANCE (Brush or Spray)
GF's best performing brush on finish with very similar performance testing as our Poly. (High Performance can be thinned for spraying).
Dries clear.
Watch High Performance Product Overview Video Here
FLAT OUT FLAT (Brush or Spray)
Flat Out Flat is formulated with a self cross-linking acrylic, and is designed to mimic the look and feel of a wax finish. Because of the increased matting agents used to create the "Flat look", this finish will have less clarity. Like wax, it dries softer to the touch than High Performance when completely cured, and will show more fingerprints. FOF finish will mark up more easily because of increased matting agents used to reduce the sheen, so it is not recommended for high-use tabletops.
Dries clear.
Watch Flat Out Flat Product Overview Video Here
BOTH PROFESSIONAL AND RETAIL TOPCOATS
ENDURO-VAR II (Spray or brush)
Enduro-Var II is an oil modified water-based alternative for customers that want the warm look of an oil finish in a water based coating. It looks more like an oil finish than a water coating, and can be sprayed or brushed. The original Enduro-Var adheres well ONLY over WATER STAINS, DYE STAINS, and RAW WOOD. Use over other finishes at your own risk. The new formula of Enduro-Var II is compatible with all GF products and dries to a lighter amber than the previous formula.
Dries Amber
Watch Enduro-Var II Product Overview Video Here
EXTERIOR 45O TOPCOAT
Exterior 450 provides a clear drying tough, protective finish that will withstand the rigors of the sun, rain, and wind. It is suitable for vertical surfaces such as fences, patio furniture, garage doors, entrance doors, outdoor kitchens and interior windows. It is not recommended as a deck finish. Fortified with UV absorbers to stabilize the finish, Exterior 450's built-in mildewcide retards mold and mildew growth.
Dries Clear
