Dye Stain Reducer is the clear base we use when manufacturing General Finishes Dye Stain and can be used to make custom Dye Stain colors by mixing with GF water base stains. It can also be used to layer color under other water or oil base stains.
General Finishes Water-Based Pre-Stain Conditioner is essentially a water-based stain formula without added color. Apply it before a water-based stain to minimize blotchiness on woods like maple, pine, and cherry.
GF's Exterior 450 Stains are low VOC premium quality, exterior pigmented water-based wood stains designed for outdoor projects with vertical surfaces such as garage doors, entrance doors and furniture.
Doug Parsons of D A Parsons Construction of Chesapeake, VA constructed a walk in closet and bathroom addition from cherry wood.
Water-Based Wood Stains from General Finishes
Newly formulated Enduro Stain Blocker is General Finishes' revolutionary water-based stain-blocking primer that now provides improved sandability and advanced performance for interior AND exterior projects. It can protect pigmented finishes from stains, dyes, and wood tannin bleed-through.
Pre-Stain Wood Conditioner with an oil-based stain is designed for use before staining new, soft, and porous wood surfaces, such as aspen, cherry, birch, poplar, or pine.
