We love this dropleaf maple table with two chairs refinished in red pepper and antique white
General Finishes is happy to announce our November 2016 Retailer of the Month, Vinterest Antiques of Hixson, TN.
Decorative Finishes- Distressing, Antique Finishes, Faux Marble and More
Got the blues? We sure do... Coastal Blue, that is!
Today, we want to share this makeover of a dresser up-cycled with General Finishes. Stacey of Embracing Change decided to ditch her idea of painting the project white.
This little demilune looks great in General Finishes Lamp Black and Antique White
In our newest video Chris Adams and Tom Monohan of General Finishes demonstrate how to update your existing cabinets with GF Water Based Wood Stain and Dye Stain with a technique called toning. Toning does not require any messy stripping or sanding.
General Finishes Dye Stain
GF recommends that you replace the doors if you want to use a white paint like General Finishes Antique White Milk Paint. Some things are not meant to be and painting charred doors is a recipe for trouble. The charring will bleed through.
