This buffet was updated to a modern sleek look by Kelly of Stylish Patina,stylishpatina.com with General Finishes
Meet "Rockstar", a cleverly designed Blue Buffet finished in Coastal Blue Milk Paint from General Finishes.
Rev up your brushes and save the date! The 2016 GENERAL FINISHES DESIGN CHALLENGE CONTEST kicks off July 4th, 2016. We will post the link to the contest at that time.
No, it is too thin. And High Performance is not thick enough for transfers either. Stick with Modge Podge.
As the Gel Stain is used, the volume of stain in the can is displaced with air, causing the stain to start curing. Gel Stains harden up more quickly than liquid oil stains for all the reasons folks love them - the extra colorants and solids within the stain that provide such great coverage also harden up more quickly than other stains.
During storage, the oxygen or moisture that's sealed in the container continues to cure and thicken your stored product, ruining the leftovers. Here are some tips to ensure your Gel Stain remains in great working condition.
A primer is your best defense under light-colored paint.
Another technique to avoid the slight color change that sometimes occurs when applying topcoat is to add 10-15% of the paint you are using to your topcoat. This technique layers additional coats of color over your piece as well as providing the protection of a topcoat. If you don't like measuring, just add enough paint until you can see a bit of the hue in the topcoat. This method works with a brush or a spray gun.
To maintain the full-strength protection of the topcoat, DO NOT TINT YOUR FINAL COAT of topcoat.
Diane from The Paint Factory took a vintage photo of downtown Portland Oregon and transfered the image to this table top.
Oil-based topcoats are "oxidizing" products which means that the moment it is introduced to oxygen, a chemical reaction will cause the finish to begin to harden. As topcoat is used, the empty space in the can is filled with air, furthering the curing process.
Tips to ensure your Arm-R-Seal remains in great working condition:
