Enduro White Poly is a professional high-solids, tintable, pigmented water-based wood finish engineered for cabinets and millwork. White Poly is a PFAS-free coating. Use over Enduro White Undercoat or Enduro Stain Blocker is recommended.
Enduro Black Pigmented Poly is a professional spray only, high-solids, pigmented water-based coating ideal for cabinets and millwork. Stocked in Black and White, custom colors are available for wholesale customers upon request. White can be used as tint base to achieve endless colors.
A favorite of professional/industrial finishers and OEM manufacturing facilities, Enduro Clear 1K Poly is a premium non-yellowing water-based self-crosslinking polyurethane-fortified topcoat that delivers a clear, tough, durable, and abrasion-resistant finish.
General Finishes Enduro line of water-based coatings is formulated for professional, industrial and OEM for operations. Comprehensive videos for each product are available on YouTube, and comparison charts at www.GeneralFinishes.com.
General Finishes Professional Enduro White Undercoat is similar to General Finishes Sanding Sealer with the addition of white colorant to provide a primer undercoat for white/off-white wood finishes. Want to tint to a darker color? Use Enduro Deep Base Primer instead.
General Finishes water-based Enduro Pre-Cat Lacquer clear-drying wood finish uses new technology in the polymer manufacturing process. This unique formula produces a smaller and smoother particle, translating into a big increase in film clarity.
Water-based Conversion Varnish is a clear drying, two-component, post-catalyzed urethane topcoat for professional, industrial and OEM use when high durability is needed.
The word "latex" is often a misnomer and is used everywhere to differentiate a water-based product from an oil-based product. The same as the word “Kleenex” is used to describe any type of facial tissue, regardless of the brand.
Today, "latex" is the technical term for a suspension (U.S.) or emulsion (European) of microparticles in water.
Tint General Finishes Milk Paint Clear or White base to match colors in major manufacturer's paint decks using Colorfal Zero VOC water soluble colorants.
