Wood Bowl Finish is a durable oil-and-urethane oil-based finish designed for decorative wooden bowls and turnings. For countertops actively used for chopping and cutting, use Butcher Block Oil instead.
Wood Turner's Finish is a water-oil urethane hybrid for use on wood turnings, bowls and other lathe-turned projects, now made with more than 50% RENEWABLE RESOURCES formulated from sustainable materials that decrease the carbon footprint.
Some pieces of wood contain a lot of oil and walnut can be finicky.
The oil in the walnut wood may be causing the problem you've described - a longer dry time might have been needed over an oily wood. If the wood does not dry over the next few days then it may be necessary to sand down and start over.
Unfortunately, if the first coat does not dry, the second will never dry.
Butcher Block Oil is a natural protectant for all wood surfaces that come in contact with food. Use this oil-based finish on wood cutting boards, utensils, bowls and butcher blocks.
Pre-Stain Wood Conditioner with an oil-based stain is designed for use before staining new, soft, and porous wood surfaces, such as aspen, cherry, birch, poplar, or pine.
ANSWER:
It depends! Read on, or watch this GF video demonstration: http://youtu.be/torOAQy91q4
*Here are the main questions to ask yourself:
Yes, you can use oil as long as it is mineral spirits soluble. Linseed, tung, walnut oil, danish oil will all work with Wood Bowl finish.
General Finishes offers a complete line of oil based, water based and wax products. Application techniques differ between oil based products and water based products.
Wow! Look at this great butcher block by Ultimate DIY Guy!
