Liquid Oil-Based Penetrating Stains made from the highest-quality oils, resins, and pigments to ensure your finishing project will be an easy and rewarding experience. These wipe-on stains are designed to be applied over raw wood surfaces.
Pre-Stain Wood Conditioner with an oil-based stain is designed for use before staining new, soft, and porous wood surfaces, such as aspen, cherry, birch, poplar, or pine.
Gel Stain from General Finishes is home of the popular Java Gel Stain featured across the nation's social media for upcycling furniture and cabinets.
General Finishes offers a complete line of oil based, water based and wax products. Application techniques differ between oil based products and water based products.
An unusual combination of oils, urethanes, and wax, Seal-A-Cell Clear has served craftsman for decades as the best wipe-on clear coat to get that "natural" look on beautiful woods. The oils penetrate deep into the wood to highlight the figure of the wood, and the urethane ensures durability.
Yes, you could mix up to 20% General Finishes liquid oil stains with General Finishes Gel Satin Topcoat.
Make your wood finishing project's grain really "POP" by layering oil & water-based products together, resulting in enhanced natural wood grain and character.
Maple is one of the most difficult woods to achieve a dark, uniform stain color on because it is a dense, closed grain wood and often absorbs stain very unevenly. General Finishes Gel Stains or Water Based Stains usually will perform very well because they are more topical than traditional liquid oil stains, and contain more colorants.
Yes, you can mix similar products together at any ratio to make more color options.
You can also mix with 10% General Finishes Liquid Oil Based Wood Penetrating Stains to obtain a slightly thinner stain than the normal Gel Stain formula.
Putty comes in two forms, pre-colored or as a stainable wood filler designed to fill minor imperfection such as nail holes, cracks, and gouges in the wood surface. Putty will display stain a bit differently than wood, so it is not a "perfect" fix, but a good one.
The goal is to get the best possible color match to either the color of the raw wood or the color of your existing finish.
