Dye Stain Reducer is the clear base we use when manufacturing General Finishes Dye Stain and can be used to make custom Dye Stain colors by mixing with GF water base stains. It can also be used to layer color under other water or oil base stains.
Doug Parsons of D A Parsons Construction of Chesapeake, VA constructed a walk in closet and bathroom addition from cherry wood.
General Finishes Water-Based Pre-Stain Conditioner is essentially a water-based stain formula without added color. Apply it before a water-based stain to minimize blotchiness on woods like maple, pine, and cherry.
Newly formulated Enduro Stain Blocker is General Finishes' revolutionary water-based stain-blocking primer that now provides improved sandability and advanced performance for interior AND exterior projects. It can protect pigmented finishes from stains, dyes, and wood tannin bleed-through.
