Enduro Professional Water-Based Conversion Varnish
Water-based Conversion Varnish is a clear drying, two-component, post-catalyzed urethane topcoat for professional, industrial and OEM use when high durability is needed. Use this wood finish for high-use projects that receive more use, such as bars, commercial tabletops, bathroom vanities, around dishwashers, kitchen cabinets or high-moisture areas. Learn more about General Finishes' entire paint system of clear and pigmented primers, acrylic and polyurethane clears, pigmented topcoats and water-based stains here:
4 Reasons to Switch to Water-Based FinishesSpray tip recommendations here. Made in the U.S.A. by General Finishes.
general finishes' enduro conversion varnish water based finish
Raw wood
New Stained Surface: Do not sand. Apply directly to the stained surface.
Pre-Finished Wood & Sealed Surfaces
  2. Dry 1-2 hours.
  4. Remove Dust
Other Substrates: Interior MDF, HDF, & Masonite
Can be used with proper preparation & priming. Always test first.
Step 2: How To Apply General Finishes Enduro Conversion Varnish
General Finishes Conversion Varnish is a clear drying, post-catalyzed, high-solids, two-component urethane formulated for ultimate durability and chemical resistance, and requires General Finishes NCO Catalyst. READ PROTECTION INSTRUCTIONS IN WARNINGS SECTION BELOW BEFORE USE.
CAUTION: Do NOT use GF Conversion Varnish or any other clear coat, over white or light paints such as GF Milk Paint, or GF White Poly as it may cause yellowing. Any clear coat can become reactive over wood substrates or existing finishes, causing tannin or dye bleed-though regardless of priming. All of GF's white paints do NOT require a topcoat.
Download 2024 Professional Water Based Product Catalog here.
Conversion Varnish Application Steps
  1. Watch product overview video here or comparison video of our topcoats here.
  3. Stir thoroughly to reincorporate solids that have settled to the bottom of the can using a power drill and mixer (recommended) or by hand with a paint stick. Do not shake. See this video here: How To Mix Conversion Varnish
  4. Test for adhesion when applying over an existing finish.
  5. Thin as desired, with distilled water (before or after mixing with NCO catalyst); start with 5%,adding up to 10% by volume.
  6. Increase open time, if needed, with 10-15% by volume of General Finishes Extender if allowed by local regulations. GF Extender can be used to improve flow and leveling, and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the product non-compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
  7. Slowly add up to 10% NCO Catalyst by volume (3.2 oz. per quart; 12.8 oz. per gallon) to Conversion Varnish while stirring thoroughly. Allow 2-3 minutes when mixing with a power drill, or 5 minutes when mixing by hand with a paint stick. Use gloves and protective eyewear when mixing. Mix only what you are going to use and clean spray gun immediately after use. The finish can only be mixed once, and the leftover product will solidify after 6-8 hours. DO NOT store in a closed container to avoid pressure build-up.
  8. Let Conversion Varnish sit for 15 minutes.
  9. Apply 3 coats. For high-moisture areas, apply 4 coats. Additional coats will not improve durability.
    • Spray application: Before spraying, strain topcoat through a fine-mesh filter. Spray wet films at 3-5-mil thickness. HVLP: 1.1mm-1.3mm spray tip, medium air cap. Verify tip sizes with your equipment supplier. Spray tip recommendations. Keep your gun at a 90° angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 25% to conceal lines. NOTE; Conversion Varnish is used with NCO catalyst. When using a spray-gun, wear self-contained breathing apparatus. In the event of insufficient ventilation: Wear self-contained breathing apparatus. When respirators are required, select NIOSH/MSHA approved equipment and work in a ventilated space. READ ALL PROTECTION INSTRUCTIONS IN THE WARNINGS SECTION BEFORE USE.
    • Face frames on cabinets: Enduro professional products are engineered to be spray-only but can be successfully applied by hand to cabinet face frames or edges with a pad applicator or small, cabinet-specific roller such as Whizz Velour brand. Larger areas may not level with a hand application.
  10. If a faster build is desired when applying clears over raw wood, use General Finishes Sanding Sealer for the first coat, followed by 2 coats of Enduro Conversion Varnish.
  11. Finish sand between coats with a fine-grade (220-320) foam sanding pad to improve smoothness and adhesion.
  12. Remove dust with a vacuum, compressed air, an oil-free tack cloth or a water-dampened rag.
Toning/Tinting
Conversion Varnish cannot be used as a toner and is not tintable.
Dry Time Based on ideal conditions of 70°F 21°C; 50% humidity.
To touch: 30+ minutes
Recoat: 1+ hours
Be sure to allow adequate dry time. Dry times are dependent on application method and environmental conditions. You can tell if a water-based finish is dry if it forms a powder when lightly sanded with a fine-grade (220-320) foam sanding pad or 400-grit sandpaper. If in doubt, wait longer. Rushing the dry time can cause "blush," which is clouding in the finish due to moisture trapped between the layers.
  • Temperatures are cooler.
Yellowing & Clear Topcoat
There is no reliable way to predict whether yellowing will occur and to what degree. Every existing finish is different and we rarely know the finishing provenance on an existing piece. Every tree is different and every piece of wood is unique. Raw wood can bleed tannins immediately after the topcoat dries or months later with seasonal temperature changes. Oak, pine, mahogany, and Douglas fir are particularly prone to bleed-through.
Summary
Tips to Prevent Yellowing
  • Use a professional product such as General Finishes Enduro White Poly. It has "increased topcoat properties," is a standalone finish when 3 coats are applied, and does not require sealing with a topcoat.
Knots
Buffing 2K
The surface an be buffed after the finish has cured using wet/dry automotive sandpaper. Use GF Satin Finishing Wax as lubricant.
Do NOT use water.
Storage of General Finishes Conversion Varnish
Water-based products do not last forever, even when unopened. General Finishes products are best used within 1 year of the manufacture date listed on the bottom of the can. The life of the product may be extended with proper care and storage.
Settling
Gravity can cause some solids to settle on the bottom of the can and slight separation on the top. This is normal. If working with older Conversion, use paint mixing attachment on a drill. If the solids dissolve and clumps smooth out after mixing from the bottom, the product is in good condition for use.
  1. The finish can only be mixed once, and the leftover product will solidify after 6-8 hours.
  2. DO NOT store in a closed container to avoid pressure build-up.
  3. Store in moderate temperatures. Avoid temperatures below 50°F/10°C or above 100°F/26°C. Frozen and heat-damaged product cannot be revitalized. Temperature-controlled spaces, such as a basement, are ideal for storage. Do not store product in an attic, garage, in direct sunlight, or next to something warm like a water heater or furnace.
  4. Store can upside down to create a liquid seal, minimize evaporation and reduce the chance of crystallization.
Warnings NCO Catalyst | Conversion Varnish | Warranties
NOTE: Conversion Varnish Is used with NCO post catalyzer. Do not breathe mist/vapours/spray. Wear protective gloves/protective clothing/eye protection/face protection. Read all protection guidelines below.
Hand protection:
Use suitable chemical-resistant protective gloves. The selection of gloves must take into account the extent and duration of use at the workstation. Protective gloves must be chosen according to the function of the work station: other chemicals which may be handled, physical protection necessary (resistance to cutting, puncture, heat), dexterity required.
Eye/face protection:
Eye and face protection requirements will vary dependent upon work environment conditions and material handling practices. Appropriate ANSI Z87 approved equipment should be selected for the particular use intended for this material. Eye contact should be prevented through use of chemical safety glasses with side shields or splash-proof goggles. An emergency eyewash must be readily accessible to the work area.
When using a spray-gun, wear self-contained breathing apparatus. In the event of insufficient ventilation: Wear self-contained breathing apparatus. When respirators are required, select NIOSH/MSHA approved equipment based on actual or potential airborne concentrations and in accordance with the appropriate regulatory standards and/ or industrial recommendations.
Body protection
Personal protective equipment for the body should be selected based on the task being performed and the risks involved and should be approved by a specialist before handling this product.
Ensure good ventilation of the work station. Shower or take a bath at the end of work. Separate normal clothes from work-clothes. Immediately remove all soiled and contaminated clothing.
Other skin protection: Appropriate footwear and any additional skin protection measures should be selected based on the task being performed. Protective clothing with elasticated cuffs and closed neck is recommended when handling NCO catalyst.
Sheen Flat (10 or less), Satin (25-35), Semi-Gloss (50-60), Gloss (80+)
Tintable No
Type Urethane/Acrylic Blend
Application Method Spray
Brushable No
Dry Time - Recoat 1+ hr
Dry Time - Light Use 72 hr
Dry Time - Cure 7 days
Can Sizes Gallons, 5 Gallon pails
Viscosity (cPs) 350-450
Flat: 29%
Satin: 28%
Semi-Gloss: 28%
Gloss: 28%
Solids by Volume
Flat: 27%
Satin: 26%
Semi-Gloss: 27%
Gloss: 27%
Flat: < 210 g/L
Satin: < 210 g/L
Semi-Gloss: < 210 g/L
Gloss: < 210 g/L
Hardness (Koenig #) 95
Wear (Taber #) 20.40 mg loss
Chemical (105 max) 101
*How Do I Spray Water Based Finishes?
Spray Tip Guidelines from General Finishes
Click the image to download a PDF of this chart
General Finishes water-based products can be sprayed through compressed air, HVLP, airless or C.A.S. units.
DOWNLOAD SPRAY TIP CHART PDF
SURFACE PREPARATION:
All surfaces should be clean and free from dirt and oil and sanded.
Indicated below are instructional videos we have for preparing a surface for a new coat of paint or finish:
PRE SEALING:
  • Milk Paint: 1.8mm-2.0mm
  • Brushable White Enamel 1.8mm-2.0mm
  • Stain Blocker: 1.8mm-2.0mm
  • Pearl Effects: 1.8mm-2.0mm
  • Glaze Effects: 1.8mm-2.0mm
  • High-Performance Topcoat: 1.1mm-1.3mm
  • Flat Out Flat Top Coat: 1.1mm-1.3mm
  • Enduro-Var 1.1mm-1.3mm
  • Water-Based Wood Stain: 1.1mm-1.3mm
  • Water-Based Dye Stain: 1.1mm-1.3mm
  • Exterior 450 Topcoat:1.1mm-1.3mm
  • Exterior 450 Stain: 1.1mm-1.3mm
  • Enduro Sanding Sealer: 1.3-1.4mm
  • Enduro White Poly: 1.3mm-1.5mm
  • Enduro Black Poly: 1.3mm-1.5mm
  • Enduro White Under Coat 1.5mm-1.8mm
  • Enduro Clear Poly: 1.1mm-1.3mm
  • Enduro Pre Cat Lacquer: 1.1mm-1.3mm
  • Enduro Conversion Varnish: 1.1mm-1.3mm
SPRAYING TOPCOATS:
Watch our video how to spray water-based topcoats here.
SPRAYING WATER BASED WOOD STAINS:
*Which General Finishes Products Would Work Best on a Restaurant Table?
GF has two products that would work well.
For non-professional finishers, we recommend using General Finishes Arm-R-Seal Topcoat.
Arm-R-Seal is oil based and will amber. Be sure to apply liberally with a foam brush or roller, letting the product self-level a bit. A liberal application will help you avoid streaks caused by back-brushing and pressure. Stir product thoroughly before and during application because flatting agents settle quickly in a solvent base finish.
For experienced professional finishers who spray, we recommend our two-step General Finishes Conversion Varnish, which would cure in half the time and dries clear.
Even though General Finishes products are water resistant, they are not impervious to standing water condensation (like an epoxy finish). As with any fine furniture finish, spills should be wiped up in a timely manner. We recommend using coasters to protect your wood from water condensation and pot holders to protect from heat.
How Do General Finishes Water Based Topcoats Differ?
Compare all GF Topcoats Here
Watch Video: Comparison of All GF Water Based Finishes Here
PROFESSIONAL TOPCOATS
ENDURO PRE CAT LACQUER (Spray only)
Looking for hardness, clarity and fast stack time? Pre Cat Lacquer is the choice. Use in applications where there is little risk of chemical contamination issues from substances such as ketchup, soap, chemical cleaners, or ammonia. This is the perfect spray finish for interior doors, casing, moldings, door jambs and furniture that receives light use. When you think about it, interior doors don't take a lot of wear. You might wipe them down or dust them once in a while but that is about it. PreCat Lacquer is a hard finish that provides excellent build and superior clarity at a phenomenal price point. If you are not finishing a surface such as a tabletop where you anticipate chemical contamination during use, why pay for a more expensive finish?
Dries clear.
Watch Pre Cat Lacquer Product Overview Video Here
ENDURO CLEAR POLY (Spray only)
Poly is the go-to cabinet finish. It has all the durability you need at a lower price point than Conversion Varnish. It is similar to High Performance in test measurements for chemical, water and wear resistance, but HP can be brushed and Clear Poly can't - it is already thinned for spraying. Clear Poly has a bit of an edge over High Performance in overall chemical resistance, a 98 rating vs 92.
Dries clear.
Watch Clear Poly product overview video here
ENDURO CONVERSION VARNISH (2K-Spray only)
This is our top of the line. Conversion Varnish is a post catalyzed high solids, two component urethane formulated for professionals who need the highest level of durability and chemical resistance. Varnish will cure the fastest. Requires NCO Catalyst. It is recommended for commercial applications or extremely high-wear surfaces such as countertops and bar tops
Dries clear.
Watch Conversion Varnish Product Overview Video Here
Enduro 2K Clear Poly (Spray Only)
For today's professional, industrial and OEM users, water-based Tintable 2K Clear Polyurethane is formulated to stop your biggest frustrations and provide ultimate durability for interior/exterior use. Key features are easy application, fast film build & production time, excellent adhesion, plus optimum water & chemical resistance.
Dries clear.
Watch 2K Clear Poly Product Overview Video Here
Enduro Pro Series Clear Poly
General Finishes Enduro Pro Series Clear Polyurethane is a single-component, self-cross linking polyurethane/acrylic topcoat designed for fast build with excellent flow and leveling. Priced competitively for the professional and industrial markets, Pro Series Clear is tintable and meets or exceeds KCMA standards. Recommended use is interior cabinets, trim, doors, and furniture. Use over raw, stained, or primed wood substrates.
Dries clear.
RETAIL TOPCOATS
HIGH PERFORMANCE (Brush or Spray)
GF's best performing brush on finish with very similar performance testing as our Poly. (High Performance can be thinned for spraying).
Dries clear.
Watch High Performance Product Overview Video Here
FLAT OUT FLAT (Brush or Spray)
Flat Out Flat is formulated with a self cross-linking acrylic, and is designed to mimic the look and feel of a wax finish. Because of the increased matting agents used to create the "Flat look", this finish will have less clarity. Like wax, it dries softer to the touch than High Performance when completely cured, and will show more fingerprints. FOF finish will mark up more easily because of increased matting agents used to reduce the sheen, so it is not recommended for high-use tabletops.
Dries clear.
Watch Flat Out Flat Product Overview Video Here
BOTH PROFESSIONAL AND RETAIL TOPCOATS
ENDURO-VAR II (Spray or brush)
Enduro-Var II is an oil modified water-based alternative for customers that want the warm look of an oil finish in a water based coating. It looks more like an oil finish than a water coating, and can be sprayed or brushed. The original Enduro-Var adheres well ONLY over WATER STAINS, DYE STAINS, and RAW WOOD. Use over other finishes at your own risk. The new formula of Enduro-Var II is compatible with all GF products and dries to a lighter amber than the previous formula.
Dries Amber
Watch Enduro-Var II Product Overview Video Here
EXTERIOR 45O TOPCOAT
Exterior 450 provides a clear drying tough, protective finish that will withstand the rigors of the sun, rain, and wind. It is suitable for vertical surfaces such as fences, patio furniture, garage doors, entrance doors, outdoor kitchens and interior windows. It is not recommended as a deck finish. Fortified with UV absorbers to stabilize the finish, Exterior 450's built-in mildewcide retards mold and mildew growth.
Dries Clear
