A primer is your best defense under light-colored paint.
Another technique to avoid the slight color change that sometimes occurs when applying topcoat is to add 10-15% of the paint you are using to your topcoat. This technique layers additional coats of color over your piece as well as providing the protection of a topcoat. If you don't like measuring, just add enough paint until you can see a bit of the hue in the topcoat. This method works with a brush or a spray gun.
To maintain the full-strength protection of the topcoat, DO NOT TINT YOUR FINAL COAT of topcoat.
GF recommends that you replace the doors if you want to use a white paint like General Finishes Antique White Milk Paint. Some things are not meant to be and painting charred doors is a recipe for trouble. The charring will bleed through.
GF is proud to announce our September 2016 Retailer of the Month, Silverleaf Interiors!
General Finishes is happy to announce our November 2016 Retailer of the Month, Vinterest Antiques of Hixson, TN.
The wonderful folks at Woodcraft show step-by-step instructions on a "Do-It-Yourself Upcycling Project" of an entertainment center using General Finishes
We love this dropleaf maple table with two chairs refinished in red pepper and antique white
Got the blues? We sure do... Coastal Blue, that is!
Extra deep and extra bright colors have lower opacity because they start out with a clear base. Read more about how to get the best coverage for your favorite colors.
Our recommendation to fix white cabinets that have yellowed is to do a thorough sanding and precleaning and recoat with the following products:
