ANSWER: You can design your own custom glazes, washes and varnishes with General Finishes intermixable water based products. See tips and recipes below:
GF Tip: For all of the following mixes, GF recommends the following two steps:
Drabs 2 Fabs did an amazing job classing up this dresser with General Finishes
Inspiration can come from anywhere!
A primer is your best defense under light-colored paint.
Another technique to avoid the slight color change that sometimes occurs when applying topcoat is to add 10-15% of the paint you are using to your topcoat. This technique layers additional coats of color over your piece as well as providing the protection of a topcoat. If you don't like measuring, just add enough paint until you can see a bit of the hue in the topcoat. This method works with a brush or a spray gun.
To maintain the full-strength protection of the topcoat, DO NOT TINT YOUR FINAL COAT of topcoat.
GF is ecstatic to present Saw Nail and Paint as our first Featured Blogger of 2017!
This week for Woodworker Wednesday, General Finishes presents Turner Custom Furniture! They build custom furniture like dressers, tables, desks and more.
Tint General Finishes Milk Paint Clear or White base to match colors in major manufacturer's paint decks using Colorfal Zero VOC water soluble colorants.
