What a great kitchen island by Craig Bentzley!
This kitchen island got a lovely transformation by Nicole from Trash to Treasures.
We love this dropleaf maple table with two chairs refinished in red pepper and antique white
Extra deep and extra bright colors have lower opacity because they start out with a clear base. Read more about how to get the best coverage for your favorite colors.
General Finishes NEW Exterior 450 White is a water-based exterior-rated pigmented coating for use on vertical surfaces such as outdoor kitchens, entry doors, garage doors, and windows.
Finish sanding is the process of sanding between or before the final coats of topcoat. There are several options.
Be careful about just using numbers. For instance, the 220 grit sanding PAD is equivalent to 400 grit SANDPAPER. Sanding pads from different brands have similar names but different grits. Also a note on sanding pads - we like to abrade new ones a bit on raw wood and not use them straight out of the box. Used 220 sanding pads are perfect for that final sand before topcoat.
Q: Which 12 colors will remain in the Milk Paint line?
These kitchen cabinet transformations come from Cabinet Refresh. They are based in the Los Angeles area and work almost exclusively with General Finishes products. Their work is top notch! Here are a few examples of their amazing talent.
Red never looked so good!
Milk Paint Color Seperation
Milk Paint is not like a filler-based wall paint. It is engineered for high-use applications such as tabletops and cabinets that require considerably more durability than a wall. The resins that make Milk Paint durable change the properties of it, so you have to handle it differently.
The type of applicator you use will change the thickness of the film and affect the appearance GF Milk Paint.
