Finish sanding is the process of sanding between or before the final coats of topcoat. There are several options.
Be careful about just using numbers. For instance, the 220 grit sanding PAD is equivalent to 400 grit SANDPAPER. Sanding pads from different brands have similar names but different grits. Also a note on sanding pads - we like to abrade new ones a bit on raw wood and not use them straight out of the box. Used 220 sanding pads are perfect for that final sand before topcoat.
Achieve the look of antique mercury glass with this gorgeous combination!
Q: Which 12 colors will remain in the Milk Paint line?
See Jason Bedre's latest project, a custom perfume maker's desk "organ" in Mahogany. Finished in General Finishes' Satin Endurovar.
Stacey of Embracing Change upgraded a drab looking sofa table with General Finishes
Chris Adams and "celebrity guest" Nicole Genz of Rescued Furnishings show how to apply General Finishes
This week for Woodworker Wednesday, GF presents the brilliant Robert of Robert Seliger Furniture! He has been building gorgeous and elaborate furniture like desks and vanities since 1985!
We may have found the the perfect recipe for a rustic patina finish!
General Finishes is excited to show off some our new products of 2015.
