Q: Which 12 colors will remain in the Milk Paint line?
Yes.
Learn more about how to prep MDF before applying GF Milk Paint.
To prep an existing fiberglass door that has a coat of paint on it:
MDF (Medium Density Fiberboard) is tricky because there are several grades of MDF and the quality varies.
If you cannot determine the quality of the MDF, play it safe and use best practices. The concern is with the edges and ends. The core of MDF is compressed sawdust, glue and resins so when you apply paint to those areas it soaks right up.
Achieve the look of antique mercury glass with this gorgeous combination!
Got the blues? We sure do... Coastal Blue, that is!
The separation is a condition the paint industry calls "float." This is typical with specific colors, such as grays, because of the large variance in the gravities of the pigments required to create those colors. In gray, for instance, Ti02 (white) is 3.4 and black is 1.62. The lower density will float.
This phenomenon will not occur in colors with less variance in densities. Float is not unique to General Finishes products.
