Get a look as delicious as chocolate truffles with Tawny Pearl Effects applied over two coats of Dark Chocolate Milk Paint!
Q: Which 12 colors will remain in the Milk Paint line?
GF is ecstatic to present Saw Nail and Paint as our first Featured Blogger of 2017!
GF advises extra care and prep when applying any finish over laminate surfaces because they are specifically designed not to mar and therefore they are not very "sand-able", making adherence difficult.
In addition to this non-permeable surface factor, General Finishes Gel Stain is an oil-based product, and it is more difficult to obtain proper drying characteristics over a dense manufactured surface such as laminate. Gel stains, as all wood stains, were formulated to go over raw wood which has an "open" surface and can absorb some of the stain.
General Finishes Milk Paint is a premium low VOC, self-sealing interior/exterior mineral-based paint named for its low-luster sheen. So durable, it is a go-to finish for cabinets and furniture.
Possibly but not recommended - the high gloss is an issue.
Folks have successfully put Gel Stain on more surfaces than we ever dreamed of including fiber glass but if you want to proceed, TEST your procedure on the inside of a door first, let the door cure for 14 days. Then further test the finish by duplicating normal wear and tear: washing, scrubbing, scratching, etc to see if the finish bonds to the surface. It might not adhere.
Gel Stain is engineered for wood, but it has successfully adhered to more surfaces than we could have imagined. However, since tile cannot be abraded properly though sanding, lasting adhesion may be difficult if not impossible.
Milk Paint will have a better chance of adhering than Gel Stain. Dark Chocolate Milk Paint was created to match the color of Java Gel stain, for example. Both products are more likely to adhere if they are applied over a tile-appropriate primer.
