The Restoration Hardware look is fantastic, but the price can definitely be a turn off. But GF has good news! Anastasia Vintage has come up with a technique to acheive a Restoration Hardware inspired look using General Finishes products.
We named our product Milk Paint with the intention of putting a clear, bright, contemporary spin on an old fashioned furniture paint tradition. With that said, GF's Milk Paint is not a true Milk Paint as it does not contain any milk powder.
It is normal to see a bit of stain on the brush when applying the first coat of topcoat. Topcoats often pull a bit of color on the first pass, but good preparation will minimize this.
To prepare open grains woods such as raw Oak for a water-based stain, we recommend sanding with 180-grit followed by no more than 220-grit sandpaper.
General Finishes does not think light scratches on a door are so significant that it would be necessary for you to strip down the finish.
Instead of stripping, GF recommends that you try:
First, test your surface to get a sense for the color present in the wood. To do this, wipe the surface down with mineral spirits (if you are expecting to use an oil finish) or plain water (if you are expecting to use a water based finish). See the following GF video demonstration for a better understanding of this process.
Next, apply product. Here are two recipes for a lightly stained look:
We love this gorgeous Bombay chest redo by Chrissie's Collection, chrissiescollection.com, finished in General Finishes Buttermilk Yellow
