Butcher Block Oil is a natural protectant for all wood surfaces that come in contact with food. Use this oil-based finish on wood cutting boards, utensils, bowls and butcher blocks.
Orange Oil is General Finishes' most popular natural furniture care product. It is non-combustible with a fresh orange scent. Use as a cleaner, for antique restoration or as a lubricant when buffing topcoats.
It depends on the type of use you plan for your butcher-block top and the look you want.
If it is a statement piece and not intended for high use, almost any finish would work. General Finishes Arm-R-Seal Topcoat is a good choice. If you intend to prep or chop food General Finishes Butcher Block Oil should be applied.
This is General Finishes' easiest finish ever and the best oil and wax finish on the market. Hard Wax Oil is a high-quality urethane-solids polymer in a blend of oil & wax that enhances the natural look of wood.
Wood Bowl Finish is a durable oil-and-urethane oil-based finish designed for decorative wooden bowls and turnings. For countertops actively used for chopping and cutting, use Butcher Block Oil instead.
Satin Finishing Wax is a special blend of waxes designed to give finished woods a rich luster. It can be used as a polish for rubbing out new finishes or as a scratch-remover for worn surfaces. It works well over oil and water-based finishes, including Danish Oil.
Wow! Look at this great butcher block by Ultimate DIY Guy!
Even though there is internet chatter about removing wax with 3rd party products, mineral spirits or vinegar, none guarantee success.
There is an old saying in the industry. "Once you wax, you cannot go back". Nothing adheres well to wax and even after cleaning, the wood grain can become contaminated. Wax can penetrate the wood, making future paint or stain finishes or touch-ups difficult or impossible.
After your finish has cured, the best way to clean is with a water-damp rag. If your surface requires deep cleaning due to grease or grime build-up, add a speck of a strong dish detergent, such as Dawn or a bit of vinegar to your damp rag.
If need deeper cleaning, use General Finishes Orange Oil Polish.
Rubbing or Buffing out a Finish:
