Gel Satin Topcoat has been a long-time favorite finish of woodworkers, with a heavy-duty oil-and-urethane base that produces a beautiful, hand-rubbed look. Gel Satin Topcoat has a thick consistency, so there are no drips, or runs.
General Finishes Arm-R-Seal Urethane Top Coat
Yes, they can, but be sure to stay within a manufacturer's finishing system and not mix product from different brands.
  1. In General Finishes line you can add up to 20% Gel Stain or Oil Base Stain to Arm-R-Seal to deepen the color for toning purposes.
  2. Simply stir the stain into the topcoat.
  3. Keep stirring during application as solids will settle very quickly when mixed into an oil urethane-based finish.
  4. Be sure to test in a hidden area before proceeding with your entire project.
Gel Stain from General Finishes is home of the popular Java Gel Stain featured across the nation's social media for upcycling furniture and cabinets.
Arm-R-Seal Oil-Based Topcoats are made with the highest-quality urethane resin, making them extremely durable and long-lasting. Formulated to be wiped on with a cloth or applied with a foam brush, this ambering finish penetrates to provide deep-down protection for that "natural" look.
Yes, you could mix up to 20% General Finishes liquid oil stains with General Finishes Gel Satin Topcoat.
Enduro-Var II is a reformulation of our original oil-modified, ambering, water-based topcoat. It replaces original Endurovar and is made with more than 70% RENEWABLE RESOURCES formulated from sustainable materials that decrease the carbon footprint and is compatible with ALL GF products.
An unusual combination of oils, urethanes, and wax, Seal-A-Cell Clear has served craftsman for decades as the best wipe-on clear coat to get that "natural" look on beautiful woods. The oils penetrate deep into the wood to highlight the figure of the wood, and the urethane ensures durability.
