Seal-A-Cell Oil Based Sealer
An unusual combination of oils, urethanes, and wax, Seal-A-Cell Clear has served craftsman for decades as the best wipe-on clear coat to get that "natural" look on beautiful woods. The oils penetrate deep into the wood to highlight the figure of the wood, and the urethane ensures durability. Seal-A-Cell is to be used as a basecoat for GF Arm-R-Seal but can be used as a stand-alone finish. Use as a wood conditioner to control the penetration of stains or intermix with GF oil-based stains to dilute or create custom colors.
General Finishes Clear Oil Based Seal-a-Cell, Quart
RAW WOOD:
1. Sand open grain wood with 120 grit sandpaper, followed by 150 grit, then 180 grit. Sand closed grain wood with 150 grit sandpaper followed by 220 grit.
Step 2: How To Apply General Finishes Seal-A-Cell
Seal-A-Cell Application Steps:
  1. Watch Seal-A-Cell Product Overview Video
  3. Stir thoroughly to reincorporate solids that have settled to the bottom of the can before use.
  4. Test for adhesion
  5. Apply 1-2 coats.
  6. Apply a liberal amount of product using a natural bristle brush, foam brush, pad applicator, staining pad or cotton cloth. Wipe along the wood grain using smooth, even strokes. Avoid heavy pressure and back brushing.
  7. Wipe off excess evenly with the grain and with light pressure using a cloth or absorbent paper towel.
  8. Apply first coat of topcoat before sanding.
Topcoat:  Topcoat with Arm-R-Seal or Gel Topcoat to enhance durability.
Application As A Wood Conditioner
  1. Seal-A-Cell can be used to control stain penetration and prevent blotching on difficult-to-stain woods such as cherry, poplar, and pine.
  2. Apply one coat with a brush or rag, then wipe off excess. Immediately apply General Finishes Oil Based Gel Stain or Liquid Oil Based Stain over wet Seal-A-Cell.
  3. Let dry overnight
  4. Topcoat with General Finishes Arm-R-Seal or Gel Satin Topcoat. Seal-A-Cell has a very small amount of wax, but not enough to interfere with adhesion.
  5. When using wood conditioners, the stain color will be 20% lighter. Apply a second coat for a deeper, richer color if desired.
Creating Custom Oil Based Stain Colors
  1. Seal-A-Cell can be used as an oil based clear stain base.
  2. Add universal tints to Seal-A-Cell to achieve custom colored stains.
  3. To dilute or lighten the color of General Finishes oil-based stains, add Seal-A-Cell Clear.
High Use Surfaces
  1. Seal-A-Cell is durable as a stand-alone finish on a table top, but if you are refinishing a high-use surface that will make regular contact with water, household chemicals and wear, we recommend using Arm-R-Seal instead. Seal-A-Cell has modified linseed oil which will pop the grain more, but Arm-R-Seal is more durable overall because of its high urethane content.
  2. To get the best of both finishes, apply a base coat of Seal-A-Cell to pop the wood grain and then top that with 2 coats Arm-R-Seal for durability. Let Seal-A-Cell dry completely before adding a second coat.
Dry Time Between Coats
Dry 24+ hours between coats when applying over raw or stained raw wood, and dry 72+ hours between coats when working over an existing sealed finish in ideal conditions: 70°F/20°C; 50% humidity.
Inadequate dry time is one of the top reasons for finish failure.
  • To accelerate dry time in humid conditions, work in a space with good ventilation and air movement. If you decide to re-coat before the recommended time, test dryness.
Cure Time Before Use
Oil-based finishes cure and harden completely after 30 days. Avoid placing heavy objects on surfaces that have not completely cured. Treat gently, and do not clean with commercial products during the cure period.
Storage of Oil Based Products
Seal-A-Cell Warnings and Warranties
Prop 65 WARNING: This product can expose you to Ethylbenzene, which is known to the State of California to cause cancer. For more information go to www.P65Warnings.ca.gov.
DANGER: COMBUSTIBLE LIQUID AND VAPOR. HARMFUL OR FATAL IF SWALLOWED. CAUSES EYE IRRITATION.
DANGER: Can enter lungs and cause damage. DANGER: Keep out of reach of children. Keep away from heat and flame. Use only with adequate ventilation. Do not breathe vapor or mist. Do not swallow. Avoid contact with eyes. Keep container tightly closed when not in use. Wash thoroughly after handling.
Product Colors Dries Amber
Ambering Yes
Sheen Gloss (80+)
Type Oil, Urethane & Wax Blend
Coats 1 - 2 coats
Application Method Brush
Dry Time - Touch 12+ hr
Dry Time - Recoat 24+ hr
Dry Time - Cure 30 days
Coverage 50-60 sq.ft./pint, 100-125 sq.ft./quart, 400-500 sq.ft./gallon
Viscosity Thin
Viscosity (cPs) 100-200
Weight Solids 33%
<564.553 g/L
Hardness (Koenig #) 77
Wear (Taber #) 57.10 mg loss
Chemical (105 max) 90
