Enduro Sanding Sealer from General Finishes
Sanding Sealer is a water base acrylic basecoat. It provides initial sealing for all GF water base topcoats and can be used over raw wood or a stained surface.
Sanding Sealer has been sterated so it will sand easier. Sanding Sealer is not as durable as the topcoats so it is not recommended for a final finish. Drying Time: 1-2 hours under normal conditions. (70 degrees F - 70% humidity)
WARNING: TEST FOR COMPATIBILITY WHEN USING THIS PRODUCT WITH PRODUCTS FROM OTHER BRANDS. General Finishes products should be tested to your complete satisfaction before using. General Finishes will not be responsible for any failure if our products are used in conjunction with other brands of finishes. We do not test General Finishes products with those of another manufacturer and will not accept liability if there is a compatibility issue.
Technical Data Sheets
Safety Data Sheets
