Glaze Effects Clear Base for Custom Glazes
Make your own custom glazes by mixing with GF water-based paints & stains, or use to dilute GF Glaze Effects colors. Glaze Effects Clear Base is the base used to make General Finishes Glaze Effects. Glaze Effects is a PFAS-free formula. As General Finishes strives for a cleaner and healthier environment, all future product development will be free of “Forever Chemicals."
The referenced media source is missing and needs to be re-embedded.
General Finishes Clear Base Glaze Effects, Quart
RAW WOOD: Not recommended. Apply over a SEALED surface such as GF Milk Paint or topcoat.
NEWLY SEALED: Does not require prep cleaning. Sand lightly with 220-320 grit foam sanding sponge and remove dust.
EXISTING SEALED SURFACE: Scuff clean with a Scotch-Brite™ pad or maroon synthetic steel wool & 50/50 mix of denatured alcohol and water. Dry 1-2 hours. Sand lightly with 220-320 grit foam sanding sponge. Remove dust. Watch our video How to Prep and Existing Finish
Step 2: How To Apply General Finishes Glaze Effects
Download 2024 Glaze Effects Brochure Here
General Finishes Glaze Effects Application Steps
For less color & more control of depth and placement of glaze color, apply Glaze Effects over 1 coat of General Finishes High Performance Topcoat, any sheen. For a deeper color, apply directly over stain or paint. Test for adhesion over existing finishes before completing the project.
  2. Stir thoroughly to reincorporate solids that have settled to the bottom of the can before and throughout the application process.
  3. Test color. To lighten, dilute with water based GF Glaze Effects Clear Base.
  4. Thin as desired with distilled water; start with 5%, adding up to 10% by volume.
  5. Increase open time, if needed, with 10-15% General Finishes Extender if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the products non-compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
  6. Apply 1+ coats:
    • Hand application: Apply a liberal coat using a synthetic bristle brush, foam brush, pad applicator or microfiber roller with smooth, even strokes. Wipe off excess with a cloth, high-quality absorbent paper towel or dry bristle brush. Do not use t-shirts.
    • Spray application: Strain with a medium-mesh filter. Spray wet films at 3-5-mil thickness. HVLP: 1.3mm-2.0mm spray tip, medium air cap. Verify tip sizes with equipment supplier. See our general guide for spray tip sizes. Wear NIOSH-approved respiratory & eye protection. Read here for more information on spraying techniques. Wipe off excess with a cloth, high-quality absorbent paper towel or dry bristle brush. Do not use t-shirts.
  7. Sand between coats with 220-320 grit foam sanding sponge. Do not use conventional steel wool. Remove dust.
  8. Seal with 3 coats of topcoat.
  9. Dry 3+ hours between coats and before GF water based topcoat in ideal conditions: 70°F/21°C; 50% humidity. Dry times may vary based on additive and mix-concentration used. Cooler temperatures & higher humidity may prolong dry time. Dry 24+ hours before applying GF oil-based products.  Increase dry time if:
    • A thick coat is applied
Step 3: Topcoat over Glaze Effects
ALWAYS seal General Finishes Glaze Effects with 3 coats of clear topcoat, e.g. General Finishes High Performance Topcoat. Apply a total of 3+ coats of topcoat altogether. If 1 coat of topcoat is applied before Glaze Effects, add at least 2 more coats over the glaze to seal in the color.
Topcoat Recommendations
Creative Techniques Using Clear Base
For the mixes listed below, General Finishes recommends the following two steps:
  1. Applying a base layer of General Finishes High Performance Topcoat before applying your custom glaze.
  2. Protect all of these finishes with 2-3 coats of topcoat when you are finished.
Custom Stain Colors:
MATERIALS NEEDED:
SAMPLE MIXES:
  1. 1 part Milk Paint + 1 part Glaze Effects Clear Base [50:50 mix]
Proportions are relative to the color you are reducing. Some colors may require 2 parts Clear Base to reduce strength, others may require 1.bBegin with a 50:50 mix, and add more Clear Base as needed.
Increase your color palette by mixing 2 or 3 Milk Paint colors together before adding the Clear Base.
Milk Paint & Glaze Effects Samples
Product Colors Clear
Interior or Exterior Interior
Type Glaze
Application Method Brush, Spray
Dry Time - Touch 1+ hr
Dry Time - Recoat 3+ hr
Coverage 60-80 sq.ft./pint, 120-160 sq.ft./quart, 480-640 sq.ft./gallon
Weight Solids 22%
295.605 g/L
*Does Glaze Effects Require Topcoat?
Absolutely. All stains and glazes require a sealant. Think of the stain or glaze as the color and the topcoat as protection.
*How Can I Create a Custom Glaze, Wash, Varnish or Stain?
  1. Applying a base layer of High Performance Top Coat before applying your custom glaze.
  2. Protect all of these finishes with 2-3 coats of top coat when you are finished.
PASTEL GLAZE/WHITEWASH:
Milk Paint + Winter White Glaze Effects OR Milk Paint + Water Based Whitewash Wood Stain
NOTE: Do not add more than 50% paint. If you add more than 50% you will have so much pigment that it will be difficult to wipe away the finish. **Do not mix Glaze Effects with Water Based Wood Stain.
CUSTOM GLAZE:
For example, Pitch Black Glaze Effects + Winter White Glaze Effects
Experiment with proportions and colors.
WOOD STAIN AS A GLAZE:
Water Based Wood Stain + 10% High Performance Top Coat
OR
Oil Based Wood Stain + 10% Mineral Spirits
Note: Make sure that you wait 72 hours before applying a water-based topcoat on top of an oil-based stain.
AGED/VARNISH GLAZE:
Water Based Wood Stain  + High Performance Top Coat 50:50 ratio
OR
Dye Stain + High Performance Top Coat 50:50 ratio
CUSTOM STAIN COLORS:
1 part Milk Paint + 1 part Pre-Stain Natural [50:50 mix]
OR
1 part Milk Paint + 1 part Glaze Effects - Clear Base [50:50 mix]
OR
1 part Milk Paint +  2 parts Water Based Stain Natural [1:2 parts]
Note: Proportions are relative to the color you are reducing. Some colors may require 2 parts clear base to reduce strength, others may require 1. Begin with a 50:50 mix, and add more clear base if necessary.
You can further increase the color palette by mixing 2 or 3 Milk Paint colors together before adding the clear base.
*Is Topcoat Required Between Gel Stain and Water Based Glaze Effects?
Yes - this is not a good place to take shortcuts. GF Gel Stain gets its deep rich hue from a large number of colorants. Seal the stain with a topcoat before applying glaze to prevent "color pull."
The glaze will also glide more easily over the surface after topcoat is applied, allowing you greater control of how much color you want to use. Be sure to wait 72 hours when applying water-based finishes over oil-based finishes.
Here is a sample finish schedule:
  1. Prep sand and clean
  2. Apply stain
  3. Apply a layer of topcoat to prevent color bleed thru and make glazing easier
  4. Apply Glaze Effects
  5. Apply 2-3 coats of topcoat to protect the entire project
Can Glaze Effects be sealed with wax instead of top coat?
Yes, you can use Satin Wax instead of top coat if you prefer. Although GF loves the look of wax, we recommend using top coat because wax is not as durable. Wax requires annual maintenance and it must be removed if you want to apply topcoat in the future.
