GF presents Scott of Oak Mountain Custom Woodwork for this week's Woodworker Wednesday! He specializes in hand-made furniture, cabinetry and millwork.
GF is ecstatic to present Saw Nail and Paint as our first Featured Blogger of 2017!
Terri Blau of Arizona attended a Sweet-Stops' milk painting class to learn finishing techniques by Tattered Nest {Vintage Marketplace} and
Lisa from General Finishes created this lovely Trumeau Mirror with Efex mouldings and General Finishes products. Trumeau mirrors are wall mirrors that were originally manufactured in France in the 18th century. The French word treameau designates the space between windows.
This is a guesstimate as GF cannot assist with the performance of another manufacturer's product used in conjunction with our own finishes.
It looks like Annie Sloan Chalk Paint is absorbing some of the topcoat because it is so porous. High Performance does not streak over a sealed surface when properly applied. Most likely the chalk paint is so dry it is pulling some of the solvents away from the High Performance, causing an uneven finish or the appearance of streaking. This happens on the original powder Chalk or Milk Paints also.
All bright white paint will yellow slightly with time, even without topcoat. You have probably tried to touch up white woodwork in your home after several years and noticed that the new paint is brighter.
But white and light paints can react if clear coated with a waterbased finish; water-based topcoats are reactive and may draw out substances in the wood such as tannins, dyes or unknown substances in existing finishes causing the topcoat to yellow. This is an industry-wide issue and can happen right away, years later or never.
In 1907 Jacob Christian Licht opened his first paint store in Chicago, Illinois with the intention of giving his customers "top quality painting products and superb service." Adding another quality painting product in 2015, General Finishes products can now be found in the Chicagoland area at all
MARK YOUR CALENDARS FOR GROUNDHOG DAY. The General Finishes 2015 Contest Starts February 2nd and runs for 40 days. There are two categories to enter. Enter one or both as often as you wish here
1) WILD NIGHTS DESIGN CHALLENGE
The separation is a condition the paint industry calls "float." This is typical with specific colors, such as grays, because of the large variance in the gravities of the pigments required to create those colors. In gray, for instance, Ti02 (white) is 3.4 and black is 1.62. The lower density will float.
This phenomenon will not occur in colors with less variance in densities. Float is not unique to General Finishes products.
