We love this gorgeous Bombay chest redo by Chrissie's Collection, chrissiescollection.com, finished in General Finishes Buttermilk Yellow
In the following faux finish examples, several layers of GF Milk Paints, GF Glaze Effects, GF Wood Stains and GF Top Coats are combined in the tradition of old world craftsmen to create unique, distressed looks in any color palette.
Terri Blau of Arizona attended a Sweet-Stops' milk painting class to learn finishing techniques by Tattered Nest {Vintage Marketplace} and
General Finishes Milk Paint is a premium low VOC, self-sealing interior/exterior mineral-based paint named for its low-luster sheen. So durable, it is a go-to finish for cabinets and furniture.
All bright white paint will yellow slightly with time, even without topcoat. You have probably tried to touch up white woodwork in your home after several years and noticed that the new paint is brighter.
But white and light paints can react if clear coated with a waterbased finish; water-based topcoats are reactive and may draw out substances in the wood such as tannins, dyes or unknown substances in existing finishes causing the topcoat to yellow. This is an industry-wide issue and can happen right away, years later or never.
Our recommendation to fix white cabinets that have yellowed is to do a thorough sanding and precleaning and recoat with the following products:
Tint General Finishes Milk Paint Clear or White base to match colors in major manufacturer's paint decks using Colorfal Zero VOC water soluble colorants.
Meet "Rockstar", a cleverly designed Blue Buffet finished in Coastal Blue Milk Paint from General Finishes.
The ability of a paint to "hide" (cover) the existing underlying finish color is dependent on a number of factors.
One factor is colorants and the other is filler. Colorants affect the viscosity of durable furniture paints, making some paints thinner than others. GF could add more filler, making Milk Paint similar to wall paint, but that would reduce the durability.
Bright, organic colors such as blues, greens, reds, yellows and whites are thinner. Unfortunately, this a problem common among highly durable paints in the industry.
