A chic dresser transformation from a heavy piece of furniture sitting in a thrift store to an updated feminine dresser with a modern touch!
Today, we want to share this makeover of a dresser up-cycled with General Finishes. Stacey of Embracing Change decided to ditch her idea of painting the project white.
A primer is your best defense under light-colored paint.
Another technique to avoid the slight color change that sometimes occurs when applying topcoat is to add 10-15% of the paint you are using to your topcoat. This technique layers additional coats of color over your piece as well as providing the protection of a topcoat. If you don't like measuring, just add enough paint until you can see a bit of the hue in the topcoat. This method works with a brush or a spray gun.
To maintain the full-strength protection of the topcoat, DO NOT TINT YOUR FINAL COAT of topcoat.
Drabs 2 Fabs did an amazing job classing up this dresser with General Finishes
Inspiration can come from anywhere!
The Restoration Hardware look is fantastic, but the price can definitely be a turn off. But GF has good news! Anastasia Vintage has come up with a technique to acheive a Restoration Hardware inspired look using General Finishes products.
