General Finishes is delighted to announce our November 2016 Blogger of the Month, Anastasia Vintage
To prep an existing fiberglass door that has a coat of paint on it:
Q: Which 12 colors will remain in the Milk Paint line?
Yes.
Learn more about how to prep MDF before applying GF Milk Paint.
The Restoration Hardware look is fantastic, but the price can definitely be a turn off. But GF has good news! Anastasia Vintage has come up with a technique to acheive a Restoration Hardware inspired look using General Finishes products.
Achieve the look of antique mercury glass with this gorgeous combination!
In our newest video Chris Adams and Tom Monohan of General Finishes demonstrate how to update your existing cabinets with GF Water Based Wood Stain and Dye Stain with a technique called toning. Toning does not require any messy stripping or sanding.
MDF (Medium Density Fiberboard) is tricky because there are several grades of MDF and the quality varies.
If you cannot determine the quality of the MDF, play it safe and use best practices. The concern is with the edges and ends. The core of MDF is compressed sawdust, glue and resins so when you apply paint to those areas it soaks right up.
