This beautiful round side table has been finished in one of our newest water based
Extra deep and extra bright colors have lower opacity because they start out with a clear base. Read more about how to get the best coverage for your favorite colors.
We love this dropleaf maple table with two chairs refinished in red pepper and antique white
Q: Which 12 colors will remain in the Milk Paint line?
Yes.
MDF
  1. Apply Kilz or Bin 123 Primer first.
  2. MDF is not as absorbent as natural wood, so wait 2 days in between coats and before applying top coat.
  3. MDF also tends to cast a brown color. If you are using a white paint, apply a coat of SeaGull Grey first to counter the brown, and then apply a couple of coats of white over it, allowing all coats to dry 2 days.
Learn more about how to prep MDF before applying GF Milk Paint.
General Finishes is happy to announce our November 2016 Retailer of the Month, Vinterest Antiques of Hixson, TN.
MDF (Medium Density Fiberboard) is tricky because there are several grades of MDF and the quality varies.
If you cannot determine the quality of the MDF, play it safe and use best practices. The concern is with the edges and ends. The core of MDF is compressed sawdust, glue and resins so when you apply paint to those areas it soaks right up.
To prep an existing fiberglass door that has a coat of paint on it:
Achieve the look of antique mercury glass with this gorgeous combination!
Decorative Finishes- Distressing, Antique Finishes, Faux Marble and More
