MARK YOUR CALENDARS FOR GROUNDHOG DAY. The General Finishes 2015 Contest Starts February 2nd and runs for 40 days. There are two categories to enter. Enter one or both as often as you wish here
1) WILD NIGHTS DESIGN CHALLENGE
In our newest video Chris Adams and Tom Monohan of General Finishes demonstrate how to update your existing cabinets with GF Water Based Wood Stain and Dye Stain with a technique called toning. Toning does not require any messy stripping or sanding.
We may have found the the perfect recipe for a rustic patina finish!
Drabs 2 Fabs did an amazing job classing up this dresser with General Finishes
The term for white or cloudy marks is blush, caused by some type of moisture in the finish. Alcohol damage is more severe than water rings.
General Finishes tests all our topcoats against both isopropyl and denatured alcohol with results showing recovery within an hour.
In most cases, the white mark will fade if the spill is cleaned up in a timely manner. If the alcohol had been sitting on the surface for an extended period then it might not be able to bounce back.
First, test your surface to get a sense for the color present in the wood. To do this, wipe the surface down with mineral spirits (if you are expecting to use an oil finish) or plain water (if you are expecting to use a water based finish). See the following GF video demonstration for a better understanding of this process.
Next, apply product. Here are two recipes for a lightly stained look:
