Glaze Effects | Furniture | Cabinet Glazes | General Finishes
Glaze Effects are translucent water based colors used to create beautiful decorative finishes such as distressing, marble, shabby chic, burnishing, color washing, rag rolling and wood graining. Use over Water Based Wood Stains, Milk Paints, Chalk Style Paints and Pearl Effects. Glaze Effects can be inter-mixed or layered to create custom colors. They may also be layered over one another to create deeper, richer looks.
Features
USE: Indoor Only
COLORS: Burnt Umber, Clear Base, Pitch Black, Red Sienna, Van Dyke Brown, Winter White, Yellow Ochre
SANDING: Do not sand stains before applying topcoat. Sand bare wood up to 150-180 grit.
Sand opened grained wood up to 220 grit.
COATS: Normally 1 (additional coats can be applied for a darker color)
RECOAT: 1-2 hours
CURE TIME: Cure time for all General Finishes products is about 14 days under ideal conditions (70° and 70% humidity). However, this may vary slightly with humidity & temperature. Good ventilation, air movement and higher temperatures will accelerate dry time.
APPLICATION: Acrylic brush, foam brush, paint pad applicator, or spray. Apply on and wipe off.
USE OVER: GF Milk Paints, Wood Stains, pigmented Polys, and any GF water base topcoat
CLEANUP: Soap and warm water
COVERAGE: 150 sq.ft/qt
CAN SIZES: Pint, Quart, Gallon
VOC: <350 g/l ( 2.92 lbs/gal)  LOW VOC, LOW ODOR
Colors
Winter White/Driftwood
Yellow Ochre/Antique White
Red Sienna/Antique White
Burnt Umber/Antique White
Van Dyke Brown/Antique White
Pitch Black/Antique White
Application Brochures
