General Finishes water-based Enduro Pre-Cat Lacquer clear-drying wood finish uses new technology in the polymer manufacturing process. This unique formula produces a smaller and smoother particle, translating into a big increase in film clarity.
General Finishes Professional Enduro White Undercoat is similar to General Finishes Sanding Sealer with the addition of white colorant to provide a primer undercoat for white/off-white wood finishes. Want to tint to a darker color? Use Enduro Deep Base Primer instead.
There are four benefits to using sanding sealer as the first seal coat prior to topcoat
John Mosconi of Sting King Lutherie in Akron, Ohio takes us on his journey of refinishing this mandola.
Step 1: Prep and Sealing
A favorite of professional/industrial finishers and OEM manufacturing facilities, Enduro Clear 1K Poly is a premium non-yellowing water-based self-crosslinking polyurethane-fortified topcoat that delivers a clear, tough, durable, and abrasion-resistant finish.
Enduro 2K Tintable 2K White and 2K Clear Poly
Superior water-based Enduro Tintable 2K Polys made in Wisconsin for professional, industrial, and OEM users. We hope you try it out; you’ll like it.
Enduro-Var II is a reformulation of our original oil-modified, ambering, water-based topcoat. It replaces original Endurovar and is made with more than 70% RENEWABLE RESOURCES formulated from sustainable materials that decrease the carbon footprint and is compatible with ALL GF products.
