Oil Based Wipe-on Liquid Penetrating Stain
Liquid Oil-Based Penetrating Stains made from the highest-quality oils, resins, and pigments to ensure your finishing project will be an easy and rewarding experience. These wipe-on stains are designed to be applied over raw wood surfaces. General Finishes liquid oil-based is a PFAS-free formula. As we strive for a cleaner and healthier environment, all GF's future product development will be free of “Forever Chemicals."
Need some inspiration? Visit the General Finishes Design Center or Pinterest Board for oil-based wood stain ideas.
The referenced media source is missing and needs to be re-embedded.
General Finishes Liquid Oil Based Wood Stain, Pecan, Quart
All raw wood projects require preparation sanding before applying stain or wood conditioners. If you skip this critical step, your finish may be rough and uneven.
Preparation for Raw Wood
  1. Sand open grain wood with 120-grit sandpaper followed by 150-grit, then 180 grit. Sand closed grain wood with no finer than 180 grit sandpaper.
  3. Do not over-sand with fine-grit sandpapers; this will close and seal the wood grain, preventing ideal product absorption.
Step 2: How To Apply General Finishes Liquid Oil Based Stain
General Finishes Liquid Penetrating Oil Based Stain Application Steps
NOTE: Due to its white color, General Finishes White Mist Oil Base Wood Stain ambers over time.
Download 2024 Oil Based Stain Brochure Here
Hand-Application over Raw Wood:
  2. Stir stain thoroughly to reincorporate solids that have settled to the bottom of the can before and throughout the application process.
  3. Test color and your complete finishing process before starting. The stain color is affected by variances in wood and deepened with the application of topcoat.
  4. Thinning: Do NOT thin.
  5. Penetrating stains are thinner than gel stains and more prone to blotching and uneven results. If working with woods that are difficult to stain, such a pine or maple, we recommended using General Finishes Gel Stain or General Finishes Water Based Wood Stain. Optionally, an initial coat of General Finishes Pre-Stain Conditioner Natural can improve color uniformity over difficult-to-stain wood species. However, it will limit color absorption, so a darker stain may be required to get the depth of color you want.
  6. CAUTION: Contains ALIPHATIC HYDROCARBONS. VAPOR HARMFUL. Use only with adequate ventilation or wear NIOSH approved respiratory protection.
  7. Divide your project into manageable sections: top, side, drawer, door, table seam.
  8. Apply 1-2 coats using a cotton rag, natural bristle or foam brush, staining pad or pad applicator using smooth, even strokes
  9. Stain a complete section and wipe off the excess evenly with the grain using a cloth, or high-quality absorbent paper towel or shop towel. Check for missed spots and lap marks before moving to the next section.
  10. Immediately correct lap marks by rewetting the entire working area with stain and wiping off the excess.
  11. Pull excess stain out of corners and details with a natural bristle brush.
  12. Let the stain dry 24+ hours in ideal conditions: 70°F/20°C, 50% humidity. Inadequate dry time is one of the top reasons for finish failures. You can tell if an oil-based finish is dry if it is no longer tacky, cool to the touch, and if you can press a cotton ball over the surface and nothing sticks. If in doubt, wait longer. Increase dry time if:
      • Water over oil: Let oil-based product dry 72+hrs
      • Oil over water: Let water-based product dry 24+hrs
    • To accelerate drying in humid conditions, work in a space with good ventilation and air movement.
  13. Finish with 3 coats of General Finishes topcoat.
Step 3: Topcoat Over Oil Based Stain
Always seal General Finishes oil-based stains with 3 coats topcoat to lock in the color. You can use either oil-based or water-based topcoat. When layering water-based and oil-based products, increase the dry time:
  • Water over oil: Let oil-based products dry 72+hrs
  • Oil over water: Let water-based products dry 24+hrs
Do not proceed with topcoat until Gel Stain is completely dry. Inadequate dry time is one of the top reasons for Gel Stain finish failure. You can tell if an oil-based finish is dry if it is no longer tacky, and cool to the touch. If in doubt, wait longer.
DO NOT use original formula of General Finishes Enduro-Var Topcoat with oil-based products. Enduro-Var II is compatible with all GF products.
General Finishes Arm-R-Seal
  • Thinner consistency.
  • Oil-based.
  • Ambers.
  • Available in Satin, Semi-Gloss and Gloss sheens.
  • Because of its thinner consistency, Arm-R-Seal is easier to apply over large and detailed surfaces, such as kitchen cabinets.
  • General Finishes most durable retail topcoat and suitable for high-use areas.
General Finishes Gel Topcoat
  • Thick consistency.
  • Oil-based.
  • Ambers.
  • Available in Satin sheen. This satin is shinier than Arm-R-Seal satin.
  • Durable and suitable for high-use areas.
General Finishes High Performance or General Finishes Flat Out Flat Water Based Topcoat
  • Looks "white" in the can.
  • Drys clear.
  • Water cleanup.
  • Brush or spray.
  • High Performance is very durable and suitable for high-use areas.
  • Flat Out Flat is designed to look and feel like a wax finish; it is recommended for low-use projects.
Storage of Oil Based Products
Oil Based Penetrating Wood Stains Warnings and Warranties
Warnings vary by color. See product label and SDS sheets for more information.
  • American Walnut, Danish Teak:
    This product can expose you to chemicals including Ethylbenzene, Crystalline silica, respirable powder, Carbon black, respirable powder, which are known to the State of California to cause cancer. For more information go to www.P65Warnings.ca.gov.
  • Antique Cherry, Candellight, Honey, Salem, Warm Cherry:
    This product can expose you to chemicals including Ethylbenzene, Crystalline silica, respirable powder, which are known to the State of California to cause cancer. For more information go to www.P65Warnings.ca.gov.
  • Honey Maple:
    This product can expose you to chemicals including Ethylbenzene, Carbon black, respirable powder, which are known to the State of California to cause cancer. For more information go to www.P65Warnings.ca.gov.
  • Mahogany:
    This product can expose you to chemicals including Ethylbenzene, Carbon black, respirable powder, Crystalline silica, respirable powder, which are known to the State of California to cause cancer. For more information go to www.P65Warnings.ca.gov.
  • Pecan:
    This product can expose you to Ethylbenzene, which is known to the State of California to cause cancer. For more information go to www.P65Warnings.ca.gov.
  • Spiced Walnut:
    This product can expose you to chemicals including Ethylbenzene, Crystalline silica, respirable powder, Titanium dioxide, Carbon black, respirable powder, which are known to the State of California to cause cancer. For more information go to www.P65Warnings.ca.gov.
DANGER COMBUSTIBLE LIQUID AND VAPOR. HARMFUL OR FATAL IF SWALLOWED. CAUSES EYE IRRITATION.
DANGER Can enter lungs and cause damage.
DANGER Keep out of the reach of children. Keep away from heat and flame. Use only with adequate ventilation. Do not breathe vapor or mist. Do not swallow. Avoid contact with eyes. Keep container tightly closed when not use. Wash thoroughly after handling.
Product Colors American Walnut, Antique Cherry, Candlelight, Danish Teak, Flint, Honey Maple, Mahogany, Mocha, Pecan, Salem, Slate, Spiced Walnut, Warm Cherry
Type Oil Based Stain
Application Method Brush, Wipe On with Clean Rag, Wipe Off
Usable over existing finishes No
Dry Time - Touch 8+ hr
Dry Time - Recoat 24+ hr
Can Sizes Half-Pints, Quarts
Coverage 45-50 sq.ft./half pint, 180-200 sq.ft./quart
Viscosity Thin
Weight Solids 36%
American Walnut: <500 g/L
Antique Cherry: <500 g/L
Candlelight: <515 g/L
Danish Teak: <515 g/L
Flint: <515 g/L
Honey Maple: <550 g/L
Mahogany: <550 g/L
Mocha: <515 g/L
Pecan: <550 g/L
Salem: <550 g/L
Slate: <500 g/L
Spiced Walnut: <525 g/L
Warm Cherry: <500 g/L
Oil Based Liquid Wipe-On Wood Stain FAQs
Can Gel Satin Topcoat be tinted with GF's liquid oil based stains?
Yes, you could mix up to 20% General Finishes liquid oil stains with General Finishes Gel Satin Topcoat.
*Can I Use Interior Wood Stains Outdoors If I Coat With an Exterior Topcoat?
Watch Exterior 450 Topcoat product overview video
Watch Exterior 450 Stain product overview video
