General Finishes water-based Enduro Pre-Cat Lacquer clear-drying wood finish uses new technology in the polymer manufacturing process. This unique formula produces a smaller and smoother particle, translating into a big increase in film clarity.
General Finishes Professional Enduro White Undercoat is similar to General Finishes Sanding Sealer with the addition of white colorant to provide a primer undercoat for white/off-white wood finishes. Want to tint to a darker color? Use Enduro Deep Base Primer instead.
A favorite of professional/industrial finishers and OEM manufacturing facilities, Enduro Clear 1K Poly is a premium non-yellowing water-based self-crosslinking polyurethane-fortified topcoat that delivers a clear, tough, durable, and abrasion-resistant finish.
Enduro White Poly is a professional high-solids, tintable, pigmented water-based wood finish engineered for cabinets and millwork. White Poly is a PFAS-free coating. Use over Enduro White Undercoat or Enduro Stain Blocker is recommended.
There are four benefits to using sanding sealer as the first seal coat prior to topcoat
Water-based Conversion Varnish is a clear drying, two-component, post-catalyzed urethane topcoat for professional, industrial and OEM use when high durability is needed.
Enduro Pro Series Clear and White Polyurethane by General Finishes
ENDURO PRO SERIES SELF CROSS-LINKING CLEAR & WHITE POLY  by General Finishes
Get professional performance for a competitive price. This new pair of ENDURO topcoats are tintable, fast-hide coatings for professional and industrial use. The high solids content provides strong build and 2-coat hide when primed with Enduro White Undercoat or General Finishes Stain Blocker.
Enduro Black Pigmented Poly is a professional spray only, high-solids, pigmented water-based coating ideal for cabinets and millwork. Stocked in Black and White, custom colors are available for wholesale customers upon request. White can be used as tint base to achieve endless colors.
