- VOC compliant in all 50 states
- Water cleanup
- Low odor
- Non-flammable
- An epoxy acrylic formulation.
- Prevents tannin bleed-through & discoloration.
- Has high build with excellent adhesion properties.
- Apply with a brush, roller, or sprayer.
- An Interior polyurethane/acrylic blend.
- Clear drying.
- highly resistant to water and household chemicals.
- Apply with a brush or sprayer.
- An interior acrylic formulation.
- Clear drying.
- provides an extremely flat finish with high durability.
- An interior oil-modified water-based urethane.
- Dries to a light, amber tone.
- Made with over 50% renewable resources.
- A premium interior and exterior-rated acrylic formulation.
- Self-sealing and does not require topcoat.
- Is made with over 50% renewable resources.
- Is available in 12 popular colors, plus two tint bases.
- An interior oxidating acrylic formula.
- Available in 6 colors, including a Clear Base.
- Is a decorative specialty finish.
- Can be intermixed to create custom colors.
- It requires a topcoat
- An interior polyurethane.
- Clear drying.
- Levels to a smooth, hard, durable finish.
- Provides excellent slip and black heel mark resistance.
- Apply with a brush, roller, or pad applicator.
- It’s available in 18 deep brilliant colors.
- And provides universal coverage on many wood species.
- Used to control blotching on hard-to-stain woods.
- And to reduce Water Based Wood Stains.
- A penetrating stain with ink-like consistency.
- It is available in 14 vibrant colors.
- And can be used as a toner.
- Apply with a brush or sprayer or wiping on.
- The clear base used to reduce Dye Stain colors.
- A polyurethane formulation.
- Tintable to dark colors.
- Contains UV absorbers & Mildewcides to protect the finish.
- Clear drying.
- A pigmented polyurethane formulation.
- Is tintable to light and pastel colors.
- Contains UV absorbers & mildewcides to protect the finish.
- Available in 10 colors, including a clear base.
- Contains U.V. absorbers & mildewcides to protect the finish.
- A premium Interior and exterior-rated acrylic formulation.
- Available in 12 popular colors, plus two tint bases.
- Apply with a brush, roller or sprayer.
- A penetrating oil wood preservative.
- Contains UV absorbers and mildewcides to protect the finish.
- This finish will amber as it ages.
- A maintenance product. Reapply when wear becomes evident.
- A heavy-bodied, no-drip oil and urethane formula.
- Designed to provide a hand-rubbed look.
- Will amber as it ages.
- Apply with a brush or wipe on.
- A heavy-bodied, no-drip formula.
- Available in 14 deep, rich, uniform colors.
- Apply with a brush, roller, or wipe on.
- A penetrating sealer with a high-quality urethane formulation.
- It provides long-lasting, durable protection.
- and works beautifully on projects with detail.
- a traditional, pigmented liquid wiping stain
- Available in 14 colors
- Can be used as a toner with Arm-R-Seal
- Designed to control blotching on hard-to-stain woods.
- And penetrates the grain to promote uniform acceptance of oil stains.
- Formulated with a blend of oils, urethanes, and wax.
- Is GF’s deepest penetrating close-to-the-wood sealer.
- And the best choice for highlighting figured wood.
- A urethane-solids polymer in a blend of oil & wax.
- Enhances the natural look of wood.
- One of our easiest finishes to use.
- It’s best used with optional GF Hardener to shorten dry time and provide superior durability.
- This is a maintenance product. Reapply when wear becomes evident.
- Apply with a white pad or plastic spreader.
- A pure urethane formulation.
- Highlights figured wood beautifully
- A mineral oil formulation.
- Meets all requirements for use on wooden surfaces that come in contact with food.
- Apply with a cloth.
- A routine cleaner for cured wood finishes
- Non-combustible with a fresh orange scent
- A blend of waxes.
- Produces a soft sheen and feel over any wood finish.
- Can be used as a polish for rubbing out new finishes OR as a scratch-remover.
