Exterior 450 Water-Based Clear Outdoor Topcoat
Exterior 450 Topcoat is a tintable clear-drying low VOC finish suitable for vertical exterior surfaces, such as fences, patio furniture, garage doors and entrance doors. It is not recommended as a deck finish. Exterior 450 is fortified with UV absorbers to stabilize and protect the integrity the finish*, and built-in mildewcides to slow mold and mildew growth. It performs well as a clear coat or as an optional topcoat over darker colors General Finishes Milk Paint. Do not use over light or white paints, as yellowing may occur. *The UV additive in 450 Clear will protect the film's integrity, but will not prevent the wood from changing color from sunlight. Brush or spray. See our spray tip size recommendations here.
4 Reasons to Switch to Water-Based Finishes
General Finishes Satin Water Based Topcoat Exterior 450, Gallon
Step 1: Prep Sanding for General Finishes Exterior 450
  1. 120-grit sandpaper followed by 150-grit or 220-grit sandpaper. Do not over-sand with fine-grit sandpapers; this will close and seal the wood grain, preventing ideal color absorption. Also, do NOT use steel wool on water-based based finishes; the particles will get trapped in the finish and rust.
  3. Let dry completely before applying General Finishes Exterior 450.
New Stained Surface: Do not sand. Apply directly to stained surface.
Sealed Surface
  2. Dry 1-2 hours
  3. Sand lightly with 220-320 grit sanding sponge.
  4. Remove dust.
Step 2: How To Apply General Finishes Exterior 450 Topcoat
CAUTION: Do NOT use Exterior 450 or any other clear coat, over white or light paints such as GF Milk Paint, or GF White Poly as it may cause yellowing. Any clear coat can become reactive over wood substrates or existing finishes, causing tannin or dye bleed-though regardless of priming. All of GF's white paints are self sealing and do NOT require a topcoat.
NOTE: Exterior 450 White is designed to let the water permeate the finish; as it dries, the water releases back out to allow the finish to tighten down again.  The UV additive in 450 Clear will protect the integrity of the finish, but will not prevent the wood from changing color from sunlight.
NOTE: Exterior 450 Whiteis not intended for decks. It can be used on tabletops that do not receive direct exposure to sun and rain. As with all furniture finishes, wipe up spills in a timely manner to protect the finish.
General Finishes Exterior 450 White Application Steps
  2. Stir to reincorporate solids that have settled to the bottom of the can before and throughout the application process. Do not shake.
  3. Test for adhesion when applying over an existing finish.
  4. Thin as desired with distilled water; start with 5%, adding up to 10% by volume.
  5. Increase open time, if needed, with 10-15% General Finishes Extender if allowed by local regulations. GF Extender will improve flow and leveling and increase open time, which is helpful in dry climates. California Residents: Adding more than 2% of GF Extender will make the products non-compliant per SCAQMD Regulations. GF assumes no liability for the improper use of these products.
  6. Apply 2-3 coats of Exterior 450. No more than three coats is recommended. More coats will not improve durability.
    • Hand application: Apply a liberal amount of product using a synthetic bristle brush, foam brush, pad applicator, or roller. Avoid pressure and excessive back-brushing. Brush along the wood grain using smooth, even strokes with light lap marks. Let lap marks dry; they WILL tighten down.
    • Spray application: Before spraying, strain topcoat through a fine-mesh filter. Spray wet films at 3-5-mil thickness. HVLP: 1.1mm-1.3mm spray tip, medium air cap. Verify tip sizes with your equipment supplier. See our spray tip size recommendations here. Keep your gun at a 90° angle, 6-8" from the surface. On large, flat areas, use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 25% to conceal lines. Wear a full filter respirator (NIOSH/MSHA approved) and work in a ventilated space. Visit this FAQ for more information on spraying techniques.
  7. Finish sand between coats with a 220-320 sanding sponge to improve smoothness and adhesion. Do not use steel wool.
  8. Remove dust with a vacuum, compressed air, an oil-free tack cloth, or a water-dampened rag.
    WARNING: We do not recommend Exterior 450 White for exotic woods, ipe, teak or other dense, oily woods.
​​​​​​Dry Time Between Coats
Dry 2+ hours between coats in ideal conditions: 70°F/21°C; 50% humidity. Be sure to allow adequate dry time. You can tell if a water-based finish is dry if it forms a powder when lightly sanded with a fine-grade (220-320) foam sanding pad or 400-grit sandpaper. If in doubt, wait longer. Rushing the dry time can cause "blush," which is clouding in the finish due to moisture trapped between the layers.
Ready for exterior use: Allow to dry 5 days before exposing to the exterior elements.
Cure Time Before Use
Furniture Care & Maintenance
Allow 21 days for the finish to cure before heavy use or cleaning with commercial products.
  • As with all furniture finishes, avoid using furniture polish, cleaners or dusting sprays that contain silicone, alcohol, ammonia and anything acidic. Future finishes or touch-ups may not adhere properly or perform as desired over a contaminated surface. Some contaminants, such as silicone, seep through finish into the wood and often cannot be removed.
Exterior 450 Topcoat Warnings and Warranties
FIRST AID: Seek immediate medical attention if symptoms occur due to the following. Eye Contact: Remove any contact lenses. Flush eyes with water for 20+ minutes while lifting upper and lower eyelids. Skin Contact: Wash skin immediately upon contact. Remove contaminated shoes and clothing; clean and wash before re-use. Inhalation: Move to fresh air and loosen clothing. If not breathing, if breathing is irregular or if respiratory arrest occurs, provide artificial respiration or oxygen by trained personnel. Ingestion: Call physician immediately. Wash out mouth with water. Do not induce vomiting unless directed to do so by medical personnel. Never give anything by mouth to an unconscious person.
Prop 65 WARNING: This product can expose you to Toluene, which is known to the State of California to cause birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov.
  • Flat:
    Keep out of the reach of children. Use only with adequate ventilation. Do not swallow. Do not get on skin or clothing. Avoid contact with eyes. Avoid breathing vapor or mist. Keep container tightly closed when not in use. Wash thoroughly after handling.
  • Satin, Semi-Gloss, Gloss:
    WARNING CAUSES EYE IRRITATION. CAUSES SKIN IRRITATION.
    Keep out of the reach of children. Do not get on skin or clothing. Avoid contact with eyes. Keep container tightly closed when not in use. Wash thoroughly after handling.
Sheen Flat (10 or less), Satin (25-35), Semi-Gloss (50-60), Gloss (80+)
Interior or Exterior Exterior
Tintable Yes
Type Urethane/Acrylic Blend
Coats 2 - 3 coats
Can Sizes Quarts, Gallons, 5 Gallon pails, 55 Gallon drums
Coverage 140-160 sq.ft./quart, 560-640 sq.ft./gallon
Viscosity (cPs) 350-450
Flat: 32%
Satin: 30%
Semi-Gloss: 30%
Gloss: 30%
Solids by Volume
Flat: 31%
Satin: 29%
Semi-Gloss: 29%
Gloss: 29%
Flat: <125 g/L
Satin: <125 g/L
Semi-Gloss: <125 g/L
Gloss: <125 g/L
Hardness (Koenig #) 30
Wear (Taber #) 95.30 mg loss
Chemical (105 max) 92
*I Used Exterior 450 Over a Mix of Mineral Spirits & Trans Tint Dye Stain and the Finish is Peeling - How Do I Fix the Peeling?*
Most dyes, such as Trans Tint, can only be mixed with alcohol or water, not mineral spirits. A water-based finish, such as Exterior 450, cannot be used in conjunction with mineral spirits, even with an extended dry time. Solvents do not play well with water-based finishes.
Unfortunately, there is no fix for the peeling finish. You will have to sand the project down, apply an exterior stain and recoat with Exterior 450. Also, advise your customer that no finish will withstand the sun indefinitely. All exterior finishes need recoating and maintenance over time.
Should I use Pre-Stain Conditioner Before Staining a Douglas Fir Door to prevent blotching?
Douglas Fir is a difficult wood to stain evenly. A 50|50 mix of your Exterior 450 stain color and Exterior 450 Clear would be a better choice for an exterior conditioner. Blotching may still occur even with this procedure.
After applying the conditioner mix, let it dry 2-3 hours. Allow more time in humid weather. Then a apply the stain color of your choice. Multiple coats will deepen the color.
Watch Exterior 450 Stain Overview Video Here
What is the difference between General Finishes Outdoor Oil and Exterior 450 Outdoor Water-based Topcoat?
General Finishes Exterior 450 Topcoat & Outdoor Oil
When comparing General Finishes Outdoor Oil and Exterior 450 outdoor water-based topcoat , there are several key differences to consider:
Application and Protection
Outdoor Oil:
  • Penetrates into the wood fibers rather than forming a film on top
  • Simpler and quicker to apply - can be sprayed, rolled or brushed on and wiped off
  • Provides less overall protection compared to topcoats
  • Requires more frequent reapplication, typically annually, dependent on environmental conditions
  • Can be used on decks.
Exterior 450 Outdoor Topcoat:
  • Forms a protective film layer on the wood surface
  • More complex application process, often requiring multiple coats
  • Offers superior protection against moisture and UV damage
  • Not intended for large horizontal surfaces such as deck.
  • Lasts longer before needing reapplication, typically 3-5 years dependent on environmental conditions
Appearance and Maintenance
Outdoor Oil:
  • Enhances the natural look of the wood
  • Easier to maintain - simply clean and reapply
  • May darken the wood slightly
  • Can provide a range of sheens from matte to glossy
  • Requires more effort to refinish - may need stripping and sanding
Durability and Longevity
Outdoor Oil:
  • Less durable overall, but easy to reapply
  • Typically lasts 1-2 years before needing reapplication
  • More durable and longer-lasting protection
  • Can last 3-5 years or more with proper care
  • Includes UV protection of the film (not the wood) and mildewicides to retard the growth of mold
Composition
Outdoor Oil:
  • Contains UV inhibitors and mildewcides
  • Organic oil
  • Water-based self-crosslinking polyurethane/acrylic.
  • Often includes UV protection and other additives for durability.
In summary, outdoor oils offer more a straightforward application and maintenance but less protection. In contrast, outdoor topcoats provide superior durability and protection at the cost of more complex application and refinishing processes. Their choice depends on the specific project requirements, desired appearance, and willingness to perform regular maintenance.
What is toning finishes?
General Finishes Dye Stain
All of General Finishes water-based topcoats with the exception of Conversion Vanish can be tinted to create lightly colored finishes for toning.  It is YOUR RESPONSIBILITY TO TEST to your satisfaction before application to your entire project.
There are limits anytime you add pigments or dyes to water-based topcoats. Toning should always be done in small increments to achieve the desired color. If you are starting with a light honey tone door and you want to create an Espresso color this will take multiple coats of color including base coat of stain followed by several toning coats. It is impossible to achieve a radical color change with just 1 coat of toner.
  • Enduro Professional Pro Series Clear Poly
  • Enduro Professional Pro Series White Poly
  • High Performance Topcoat
  • Flat Out Flat Topcoat
  • Enduro-Var II Topcoat
  • Exterior 450 Topcoat
  • Wood Turners Finish
  • Exterior 450 White
  • Arm-R-Seal
  • Seal-A-Cell
  • Gel Satin Topcoat
  • Wood Bowl Finish
  • Butcher Block Oil
  • Outdoor Oil
  • Hard Wax Oil
GENERAL PRACTICE:
  1. Oil-based topcoats and ENDURO-VAR II will amber over time.
Compare all topcoats
