Enduro Clear Poly Waterbourne Topcoat General Finishes
Enduro Clear Poly is a high performing commercial grade topcoat fortified with polyurethane that delivers a very tough, durable and abrasion resistant finish. Clear Poly can be used on any project where more solids (28%) and durability are desired.
Features
Colors: Water White  (Can also be custom tinted, also available in Black & White)
Sheen: Flat, satin, semi-gloss, gloss
Recoat/Dry Time: 1-2 hours
Coats Recommended: 3
Cure Time: 21 days
Cleanup: General clean-up with soap and warm water recommended. Rinse thoroughly with clean water. For best results, clean all equipment with General Finishes Brush and Gun Cleaner.
Coverage: 600 sq ft/gal
Can Sizes: Quart, Gallon
Recommended Use: Interior
Spray Tip Sizes Recommended: .043 - .051 tip and nozzle, No. 9 - 10 air cap
VOC: < 94 g/l (0.078 lb/gal)
Viscosity:
Reviews
Received order , holy gaucamole' , that was fast !!!
4 years 30 weeks ago
Received order , holy gaucamole' , that was fast !!! If ever you need an endorsement , great product , fabulous service . Real Americans at General Finishes , for sure ... Thanx a Bunch
From Eric Iorgov, Corpus Christi
