Exterior 450 Topcoat is a tintable clear-drying low VOC finish suitable for vertical exterior surfaces, such as fences, patio furniture, garage doors and entrance doors. It is not recommended as a deck finish.
GF's Exterior 450 Stains are low VOC premium quality, exterior pigmented water-based wood stains designed for outdoor projects with vertical surfaces such as garage doors, entrance doors and furniture.
Check out this before and after shot of an adirondack chair restoration by Furniture Medic using General Finishes Exterior
General Finishes NEW Exterior 450 White is a water-based exterior-rated pigmented coating for use on vertical surfaces such as outdoor kitchens, entry doors, garage doors, and windows.
When comparing General Finishes Outdoor Oil and Exterior 450 outdoor water-based topcoat , there are several key differences to consider:
Outdoor Oil:
Outdoor Oil works by saturation. Once the wood is thoroughly oiled then wait 24-48 hours before applying oil base. Use an exterior oil varnish. Do not use a water-based finish such as Exterior 450 Topcoat.
