Wood Bowl Finish is a durable oil-and-urethane oil-based finish designed for decorative wooden bowls and turnings. For countertops actively used for chopping and cutting, use Butcher Block Oil instead.
Wow! Look at this great butcher block by Ultimate DIY Guy!
Gel Satin Topcoat has been a long-time favorite finish of woodworkers, with a heavy-duty oil-and-urethane base that produces a beautiful, hand-rubbed look. Gel Satin Topcoat has a thick consistency, so there are no drips, or runs.
It's Woodworker Wednesday and this week we're excited to feature Dave Picciuto of The Drunken Woodworker! Inspired to create affordable photo frames for himself, Dave discovered the art of woodworking and never looked back.
Wood Turner's Finish is a water-oil urethane hybrid for use on wood turnings, bowls and other lathe-turned projects, now made with more than 50% RENEWABLE RESOURCES formulated from sustainable materials that decrease the carbon footprint.
General Finishes Oil Based Urethane Arm-R-Seal Topcoat
Yes, these finishes will darken with age, even if stored in plastic cans that allow light to filter in. However, this will not harm performance if properly stored after opening. Here are some steps to store oil finishes.
  1. Decant the amount you'll need into a foil covered bowl and reseal your can right away.
  2. Be sure to REALLY clean the chime and the lid of the can to assure a tight seal.
  3. Use Bloxygen to help remove excess oxygen from your can of finish to help preserve it longer.
  4. Store your sealed cans upside down.
Butcher Block Oil is a natural protectant for all wood surfaces that come in contact with food. Use this oil-based finish on wood cutting boards, utensils, bowls and butcher blocks.
