The Restoration Hardware look is fantastic, but the price can definitely be a turn off. But GF has good news! Anastasia Vintage has come up with a technique to acheive a Restoration Hardware inspired look using General Finishes products.
GF's Get the Look series is designed to give you some inspiration for your next project!
Glamorous style isn't just for Hollywood!
Get a look as delicious as chocolate truffles with Tawny Pearl Effects applied over two coats of Dark Chocolate Milk Paint!
General Finishes Milk Paint is a premium low VOC, self-sealing interior/exterior mineral-based paint named for its low-luster sheen. So durable, it is a go-to finish for cabinets and furniture.
Milk Paint is not like a filler-based wall paint. It is engineered for high-use applications such as tabletops and cabinets that require considerably more durability than a wall. The resins that make Milk Paint durable change the properties of it, so you have to handle it differently.
The type of applicator you use will change the thickness of the film and affect the appearance GF Milk Paint.
Only 5 days until Christmas!
GF recommends that you replace the doors if you want to use a white paint like General Finishes Antique White Milk Paint. Some things are not meant to be and painting charred doors is a recipe for trouble. The charring will bleed through.
