Oil Based Gel Stain
Gel Stain from General Finishes is home of the popular Java Gel Stain featured across the nation's social media for upcycling furniture and cabinets. Gel wood stains are heavy-bodied and do not penetrate as deeply into the wood as liquid oil-based wipe-on stains, providing the deepest, richest colors of any oil-based stain. Gel Wood Stain is a PFAS-free formula. As General Finishes strives for a cleaner and healthier environment, all future product development will be free of “Forever Chemicals."
Need some inspiration? Visit the General Finishes Design Center or Pinterest Board for gel stain ideas.
The referenced media source is missing and needs to be re-embedded.
General Finishes Java Oil Based Gel Stain, Quart
Step 1: Preparation for Gel Stain
All raw wood projects require preparation sanding before applying stain, and all existing finishes require prep cleaning and sanding. If you skip this critical step, your finish may fail.
  1. Prep sand with 120-grit sandpaper followed by 150-grit sandpaper. Do not over-sand with fine-grit sandpapers; this will close and seal the wood grain, preventing ideal color absorption.
  3. Let dry completely before applying General Finishes product.
Preparation for Projects with a Sealed Surface
  1. Scuff clean with a Scotch Brite™ pad or maroon synthetic steel wool and a 50:50 mix of denatured alcohol and water. If your project requires a deeper cleaning, see Power Prep Cleaning Highly Used Existing Finishes below.
  2. Dry 1-2 hours.
  3. Sand lightly with a 220-320-grit foam sanding sponge.
  4. Remove dust with a vacuum, compressed air, a tack cloth or a water-dampened rag.
  5. Let dry completely before applying General Finishes product.
  1. Scrub clean with a detergent, such as Spic and Span or Dawn, using a Scotch Brite™ pad.
  2. Rinse well with water.
  3. Scrub clean with a Scotch Brite™ pad and a 50:50 mix of denatured alcohol and water. Dry 1-2 hours.
  4. Sand lightly with a 220-320 foam sanding pad.
  5. Remove dust with a vacuum, compressed air, a tack cloth or a water-dampened rag.
  6. Let dry completely before applying General Finishes product.
Alternative Cleaning Solutions for Existing Finishes (Not as aggressive or effective as denatured alcohol; requires rinsing.)
  1. 50:50 mix of bleach and water
  2. 50:50 mix of vinegar and water
  3. Mineral spirits can be used when working with water-based products, but only if the surface is thoroughly rinsed and allowed to dry for 72 hours.
Step 2: How To Apply General Finishes Gel Stain
Download 2024 Gel Stain Brochure Here
General Finishes Gel Stain Application Steps
  2. Stir the stain thoroughly to reincorporate solids that have settled to the bottom of the can.
  3. If desired, thin stain with mineral spirits. Start by adding 5% by volume and increase up to 15% as needed.
  4. There is usually no need for General Finishes Pre-Stain Conditioner Natural to improve color uniformity. Gel Stain is loaded with pigments that provide deep uniform coverage.
  5. TEST your complete finishing process before starting. The stain color is affected by many variances including but not limited to the wood species, type of application method, and existing finishes on the substrate. The color is further deepened with the application of topcoat.
  6. Do NOT paint on Black Gel or Carbon Gray Stain. The pigments needed to create the black color hamper drying when Gel Stain is used as a paint rather than applying in thin layers and wiping off the excess.
  7. Painting on Gel Stain is NOT a recommended technique as the surface will get very dark and dry times will be longer, 72 hours, or much longer depending on the substrate and humidity. Use either paint or a dark water-based wood stain instead if you want a solid dark color. If you still want to use Gel Stain over an existing surface, we recommend this technique instead: How To Update Kitchen Cabinets Using a Dry Brush Technique. When finishes are applied over an existing finish, dry times must be increased.
  8. Surface Preparation is essential. See "Step 1: Preparation for Gel Stain."
  9. Divide your project into manageable sections: top, side, drawer, door, table seam, etc.
1. Hand-Application over Raw Wood:
See our video on How To Apply Gel Stain to a Raw Wood Surface.
  • Optional: Apply a slip coat of mineral spirits over the raw wood immediately before application to facilitate the flow of stain on the surface and reduce lap marks. (This is not a conditioner.)
  • Working quickly, apply a LIBERAL coat with smooth, even strokes using a natural bristle brush, foam brush, pad applicator, staining pad or microfiber roller.
    Gel Stain dries quickly for all the reasons customers love it: it is loaded with colorants and solids. If not enough stain is used, the surface may dry too quickly, causing an uneven appearance.
    On large surfaces, leave a wet edge between passes to prevent lap marks. We recommend getting a buddy to help apply the stain.
  • Stain one section at a time, leaving a wet edge between sections.
  • Wipe off the excess evenly with the grain using high-quality absorbent paper towels, shop towels or open-weave cloths, such as cotton terry towels for larger projects.
    Check for missed spots and lap marks before moving to the next section.
    Do NOT use cotton t-shirts to wipe away stain because they will "push" the stain around and not absorb it.
  • Immediately correct lap marks by rewetting the entire working area with stain and wiping off the excess.
  • Pull excess stain out of corners and details with a natural bristle brush.
  • Let the stain dry 12-24 hours in ideal conditions: 70°F/20°C, 50% humidity. Inadequate dry time is one of the top reasons for Gel Stain finish failure. If in doubt, wait longer. Increase dry time if:
      • Water over oil: Let oil-based products dry 72+hr before applying water-based products
      • Oil over water: Let water-based products dry 24+hr before applying oil-based products
    • If applying stain over an existing finish, confirm that the finish has dried before applying another coat of stain or topcoat. Depending on the existing finish, Gel Stain can take days to dry. Be patient, and test by rubbing with a white cotton ball or white cloth. If the surface is still tacky or you can remove more than a faint trace of stain, the surface is not ready.
    • If Gel Stain is tacky after 5 days, dry time requirements have not been met and it may never dry. The only alternative is to strip off the finish and start over. Reminder, always test the entire finish schedule in advance before proceeding with the entire project.
  • Optional: apply a second coat to deepen the color. Apply no more than 2 coats.
  • Finish with 3 coats of General Finishes topcoat, letting each coat dry 72 hours.
2. Dry Brushing Over an Existing Finish
  • Finishes dry in two directions: through the air and through absorption in raw wood. When finishes are applied over an existing finish, dry times must be increased.
  • See our video tutorials:
  • Prep cleaning and sanding is essential. See "Step 1: Preparation for Gel Stain."
  • Test your complete finishing process before starting. The stain color is affected by variances in wood and deepened with the application of topcoat.
  • Apply stain with a natural bristle brush or foam brush. Feather out uneven areas and pull excess stain from corners using a bristle brush. Discharge accumulated stain from the brush onto a paper towel soaked with mineral spirits as you work.
  • Let the stain dry 72+ hours in ideal conditions: 70°F/20°C, 50% humidity. You can tell if an oil-based finish is dry if it is no longer tacky, and cool to the touch. If in doubt, wait longer. Increase dry time if:
    • If Gel Stain is tacky after 5 days, dry time requirements have not been met and it may never dry. The only alternative is to strip the finish off and start over.
  • Finish with 3 coats of General Finishes topcoat. See "Step 3: Topcoat Over Oil-Based Stain."
3. ​​​​​​Painting on Stain Without Wiping Away (raw wood or existing finish):
  • Painting on Gel Stain is NOT a recommended technique as the surface will get very dark and dry times will be longer, 72 hours, or much longer depending on the substrate and humidity. Use either paint or a dark water-based wood stain instead if you want a solid dark color. If you still want to use Gel Stain over an existing surface, we recommend this technique instead: How To Update Kitchen Cabinets Using a Dry Brush Technique. When finishes are applied over an existing finish, dry times must be increased.
  • Do NOT paint on Black Gel or Carbon Gray Stain. The pigments needed to create the black color hamper drying when Gel Stain is used as a paint rather than applying in thin layers and wiping off the excess.
  • When painting on Gel Stain without wiping away, let the stain dry 72+ hours or longer between coats in ideal conditions: 70°F/20°C; 50% humidity. Do not proceed with additional coats unless the stain is dry.
  • Tip: If you are using General Finishes Java Gel Stain, General Finishes recommends using General Finishes Dark Chocolate Milk Paint instead of painting on Gel Stain. This Milk Paint color matches a solid application of Java Gel Stain, is much faster to apply, and offers easy water clean-up.
Step 3: Topcoat Over Oil Based Stain
Always seal General Finishes oil-based stains with 3 coats topcoat to lock in the color. You can use either oil-based or water-based topcoat. When layering water-based and oil-based products, increase the dry time:
  • Water over oil: Let oil-based products dry 72+hrs
  • Oil over water: Let water-based products dry 24+hrs
Do not proceed with topcoat until Gel Stain is completely dry. Inadequate dry time is one of the top reasons for Gel Stain finish failure. You can tell if an oil-based finish is dry if it is no longer tacky, and cool to the touch. If in doubt, wait longer.
DO NOT use original formula of General Finishes Enduro-Var Topcoat with oil-based products. Enduro-Var II is compatible with all GF products.
General Finishes Arm-R-Seal
  • Thinner consistency.
  • Oil-based.
  • Ambers.
  • Available in Satin, Semi-Gloss and Gloss sheens.
  • Because of its thinner consistency, Arm-R-Seal is easier to apply over large and detailed surfaces, such as kitchen cabinets.
  • General Finishes most durable retail topcoat and suitable for high-use areas.
General Finishes Gel Topcoat
  • Thick consistency.
  • Oil-based.
  • Ambers.
  • Available in Satin sheen. This satin is shinier than Arm-R-Seal satin.
  • Durable and suitable for high-use areas.
General Finishes High Performance or General Finishes Flat Out Flat Water Based Topcoat
  • Looks "white" in the can.
  • Drys clear.
  • Water cleanup.
  • Brush or spray.
  • High Performance is very durable and suitable for high-use areas.
  • Flat Out Flat is designed to look and feel like a wax finish; it is recommended for low-use projects.
Creative Finishing Techniques Using Gel Stain
Mixing Gel Colors
  • Gel stains can be intermixed to create custom colors.
  • Gel Stain can be mixed with no more than 10% Liquid Oil Stain is added by volume. The liquid stain will thin the stain, which may help it spread more easily but it will not have as much coverage.
  • Gel Stain can be layered over other General Finishes water and oil-based stains. Allow for adequate dry time when layering water and oil products. See video tutorial: Can Oil and Water Based Finishes Be Applied on the Same Project
Storage of Oil Based Stains
General Finishes products do not last forever, even when unopened. They are best used within 1 year. The life of the product may be extended with proper can closure and storage conditions.
See our video: Tips on Storing Leftover Finishes
  2. Keep lid closed while working. Decant what you will use into a bowl, paper cup, or plate, and close can lid as you work. Every minute the can is open, the product is curing.
  3. Clean the chime of the can thoroughly with a paper towel before closing to create a complete seal. Product in the chime can be minimized by using a pouring lid, such as Fitsall. Avoid wiping used brushes on the lid.
  5. Store in moderate temperatures. Avoid temperatures below 50°F/10°C or above 80°F/26°C. Keep from freezing. Frozen and heat-damaged product cannot be revitalized. Temperature-controlled spaces, such as a basement, are ideal for storage. Do not store product in an attic, garage, in direct sunlight, or next to an open flame source such as a water heater or furnace.
  6. Store can upside down to create a liquid seal, minimizing oxygen exposure from within the can. Decant remaining product from the can before stirring.
  7. Add Bloxygen To Sealed Product. Bloxygen is an argon gas system that prevents oxygen and moisture from hardening leftover product. Because Bloxygen gas is heavier than air, it sinks to the surface of the leftover finish, creating a barrier between product and air trapped in the container.
  8. Decant leftovers to a smaller container when the finish is almost used up to reduce the volume of oxygen in the container.
STORING MIXTURES
  • Mixtures involving colors & sheens within the same product line CAN be stored
    E.g., Java Gel Stain + Brown Mahogany Gel Stain
  • Mixtures involving different oil-based products should NOT be stored for later use.
    E.g.: Gel Stain + Mineral Spirits (for thinning)
    Gel Stain + Liquid Oil-Based Stain
    Gel Stain + Gel Topcoat
Alternative Storage Containers
  • Glass Bottles that seal completely.
  • Do not store oil-based products in plastic bottles.
Gel Stain hardens faster than other products. It may soften slightly if a small amount of mineral spirits is added.
Gel Stain Warnings and Warranties
FIRST AID: Seek immediate medical attention if symptoms occur due to the following. EYE CONTACT: Remove any contact lenses. Flush eyes with water for 20+ minutes while lifting upper & lower eyelids. SKIN CONTACT: Flush skin with water. Remove contaminated clothing & shoes & clean before reuse. INHALATION: Move to fresh air. Loosen tight clothing. If not breathing, if breathing is irregular, or if respiratory arrest occurs, trained personnel should provide artificial respiration or oxygen. INGESTION: Call physician immediately. Wash out mouth with water. Do not induce vomiting unless directed to do so by medical personnel. Never give anything by mouth to an unconscious person.
Warnings vary by color. See product label and SDS sheets for more information.
  • American Oak, Prairie Wheat:
    WARNING: This product can expose you to chemicals including Ethylbenzene, Crystalline silica, respirable powder, which are known to the State of California to cause cancer, and Toluene, which is known to the State of California to cause birth defects or other reproductive harm.
  • Antique Walnut, Brown Mahogany, Candlelite, Colonial Maple, Nutmeg:
    WARNING: This product can expose you to chemicals including Ethylbenzene, Crystalline silica, respirable powder, which are known to the State of California to cause cancer.
  • Ash Gray, Carbon Gray:
    WARNING: This product can expose you to Benzene, which is known to the State of California to cause cancer and birth defects or other reproductive harm. This product can expose you to chemicals including Titanium dioxide, Carbon black, respirable powder, which are known to the State of California to cause cancer, and Toluene, which is known to the State of California to cause birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov
  • Black:
    WARNING: This product can expose you to Benzene, which is known to the State of California to cause cancer and birth defects or other reproductive harm. WARNING: This product can expose you to chemicals including Carbon black, respirable powder, which is known to the State of California to cause cancer, and Toluene, which is known to the State of California to cause birth defects or other reproductive harm.
  • Georgian Cherry:
    WARNING: This product can expose you to chemicals including Ethylbenzene, Crystalline silica, respirable powder, Carbon black, respirable powder, which are known to the State of California to cause cancer.
  • Gray:
    WARNING: This product can expose you to Benzene, which is known to the State of California to cause cancer and birth defects or other reproductive harm. WARNING: This product can expose you to chemicals including Titanium dioxide, Carbon black, respirable powder, which are known to the State of California to cause cancer, and Toluene, which is known to the State of California to cause birth defects or other reproductive harm.
  • Java:
    WARNING: This product can expose you to chemicals including Ethylbenzene, Cumene, Crystalline silica, respirable powder, Naphthalene, Carbon black, respirable powder, which are known to the State of California to cause cancer, and Toluene, which is known to the State of California to cause birth defects or other reproductive harm.
  • New Pine:
    WARNING: This product can expose you to chemicals including Ethylbenzene, Carbon black, respirable powder, which are known to the State of California to cause cancer, and Toluene, which is known to the State of California to cause birth defects or other reproductive harm.
  • White:
    WARNING: This product can expose you to Benzene, which is known to the State of California to cause cancer and birth defects or other reproductive harm. This product can expose you to chemicals including Ethylbenzene, Titanium dioxide, which is known to the State of California to cause cancer, and Toluene, which is known to the State of California to cause birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov
  • American Oak, Brown Mahogany, Candlelite, Colonial Maple, New Pine, Nutmeg, Prairie Wheat:
    WARNING: COMBUSTIBLE LIQUID AND VAPOR. CAUSES EYE IRRITATION
    Keep out of reach of children. Keep away from heat and flame. Use only with adequate ventilation. Avoid contact with eyes. Keep container tightly closed when not in use. Wash thoroughly after handling.
  • White:
    Keep out of the reach of children. Keep away from heat and flame. Use only with adequate ventilation. Avoid contact with eyes. Keep container tightly closed and sealed until ready for use. Wash thoroughly after handling.
  • Antique Walnut:
    WARNING: COMBUSTIBLE LIQUID AND VAPOR. HARMFUL IF INHALED. CAUSES EYE AND SKIN IRRITATION.
    Keep out of reach of children. Keep away from heat and flame. Use only with adequate ventilation. Avoid contact with eyes. Keep container tightly closed when not in use. Wash thoroughly after handling. Soaked application materials are combustible.
  • Black, Gray:
    Keep out of reach of children. Keep away from heat and flame. Use only with adequate ventilation. Do not breathe vapor or mist. Do not get on skin or clothing. Avoid contact with eyes. Keep container tightly closed when not in use. Wash thoroughly after handling.
    WARNING: COMBUSTIBLE LIQUID AND VAPOR. HARMFUL IF INHALED. CAUSES EYE IRRITATION. CAUSES SKIN IRRITATION.
    Keep out of the reach of children. Keep away from heat and flame. Use only with adequate ventilation. Do not breathe vapor or mist. Do not get on skin or clothing. Avoid contact with eyes. Keep container tightly closed and sealed until ready for use. Wash thoroughly after handling.
  • Georgian Cherry:
    WARNING: COMBUSTIBLE LIQUID AND VAPOR. HARMFUL IF INHALED. CAUSES EYE AND SKIN IRRITATION. MAY CAUSE SEVERE ALLERGIC SKIN REACTION.
  • Java:
    WARNING: COMBUSTIBLE LIQUID AND VAPOR. HARMFUL IF INHALED. CAUSES RESPIRATORY TRACT, EYE AND SKIN IRRITATION.
Product Colors American Oak, Antique Walnut, Ash Gray, Black, Brown Mahogany, Candlelite, Carbon Gray, Colonial Maple, Georgian Cherry, Gray, Java, New Pine, Nutmeg, Prairie Wheat, White
Type Oil Based Stain
Application Method Brush, Roll, Wipe On with Clean Rag
Usable over existing finishes Yes - see product page application instructions.
Dry Time - Touch Raw Wood (8+ hr), Existing Finish wipe-off (12-24+ hr), Paint on (12-72+ hr)
Dry Time - Recoat Raw Wood (12-24+ hr), Existing Finish wipe-off (72+ hr), Paint on (72+ hr)
Dry Time - Recoat - Applied Over Water Based Product 72
Can Sizes Half-Pints, Pints, Quarts, Gallons
Coverage 35-50 sq.ft./half pint, 75-100 sq.ft./pint, 150-200 sq.ft./quart, 600-800 sq.ft./gallon
Viscosity Very Thick
Viscosity (cPs) 1000-2000
Weight Solids 42%
American Oak: <500 g/L
Antique Walnut: <500 g/L
Ash Gray: <550 g/L
Black: <500 g/L
Brown Mahogany: <500 g/L
Candlelite: <500 g/L
Carbon Gray: <550 g/L
Colonial Maple: <550 g/L
Georgian Cherry: <500 g/L
Gray: <500 g/L
Java: <450 g/L
New Pine: <550 g/L
Nutmeg: <550 g/L
Prairie Wheat: <550 g/L
White: <550 g/L
Oil Based Gel Stain FAQs
Do Gel Stains Require a Topcoat?
All stains need a top coat. Think of stain as the color and top coat as the sealer and protectant.
The high urethane content of General Finishes Gel Stains results in a lustrous finish that tends to fool people into assuming no sealant is required. The beauty of Gel Stain comes from thick thick urethane which can carry a LOT of color to any surface, but that color must be sealed in with top coat. An added bonus of top coat is that it also protects the wood from drying out.
Can GF’s Gel Stain be used outdoors?
Do not use General Finishes Gel Stain or any oil based finish outside where this direct exposure to water. If your furniture will be resting under a cover and not exposed to direct water, you may have a successful result. We recommend our Milk Paint or Exterior 450 products instead.
Watch Exterior 450 Stain Overview Video Here
How can I thin Gel Stain?
Gel Stain can be mixed with up to 50% Liquid Oil Stain but be aware that this will thin the viscosity.
We recommend starting with 10% Liquid Oil Stain and testing to your satisfaction. Add more Liquid Stain as needed up to 50%. The mix will be thin and more translucent with less color saturation and intensity, but will not lose any of its properties for adhesion and curing.
How to thin Gel Stain to create a glaze
We recommend adding up to 10% mineral spirits. You can add more mineral spirits, but test first. The mixture will thin out quickly and also reduces color intensity. Using more than 10% can affect the performance and durability of the finish, but as a glaze, this is not as critical an issue because your topcoat will protect the finish.
*Will Gel Stains Darken with Another Coat?
Yes, each layer will darken your project even more. You can also start with a lighter color Gel Stain and layer on darker colors.
*How Can I Lighten the Color of the Java Gel Stain I Have Applied?
It's always possible to darken a stained surface, but you cannot lighten a stained surface after the finish has dried.
When the surface is still wet, you can try to lighten the color by scrubbing with mineral spirits. If the finish has hardened, you will need to sand down your current stain and start over or use one of our paints.
You can mix GF Gel Stain colors to create a custom color.
You can also thin Gel Stain with 10-15% mineral spirits.
Always test our color on a hidden area of your project before beginning.
*Can I Mix Gel Stain Colors Together to Achieve Other Colors?
Yes, you can mix similar products together at any ratio to make more color options.
You can also mix with 10% General Finishes Liquid Oil Based Wood Penetrating Stains to obtain a slightly thinner stain than the normal Gel Stain formula.
*How Can I Prevent Gel Stain from Hardening in the Can?
As the Gel Stain is used, the volume of stain in the can is displaced with air, causing the stain to start curing. Gel Stains harden up more quickly than liquid oil stains for all the reasons folks love them - the extra colorants and solids within the stain that provide such great coverage also harden up more quickly than other stains.
During storage, the oxygen or moisture that's sealed in the container continues to cure and thicken your stored product, ruining the leftovers. Here are some tips to ensure your Gel Stain remains in great working condition.
  • Decant the amount of stain you'll need into a foil covered bowl and reseal your can right away. Every minute the can is open the stain is curing.
  • Be sure to REALLY clean the chime and the lid of the can to assure a tight seal.
  • Use Bloxygen to help remove excess oxygen from your can of finish to help preserve it longer.
  • Store your sealed cans upside down.
  • Transfer any unused stain to a smaller container once finished with your project or buy Gel Stain in smaller cans to begin with.
  • Plastic Wrap??  Haven't tried it, but you get the idea! Anything to prevent contact with air is key.
Watch Tips on Storing Leftover Wood Finishes here.
Can Gel Stain be applied over a high gloss paint finish?
Possibly but not recommended - the high gloss is an issue.
Folks have successfully put Gel Stain on more surfaces than we ever dreamed of including fiber glass but if you want to proceed, TEST your procedure on the inside of a door first, let the door cure for 14 days. Then further test the finish by duplicating normal wear and tear: washing, scrubbing, scratching, etc to see if the finish bonds to the surface. It might not adhere.
If you want to proceed with your project, the cabinets need to be sanded with 150-180 grit sandpaper before attempting to apply the Gel Stain. If you cannot achieve enough abrasion by sanding, apply a De-Glosser, available at any paint store. We think Milk Paint would be a better choice as paint is more flexible and tends to adhere well to many surfaces, but test to your satisfaction before proceeding. Milk Paint is available in Dark Chocolate, a very close color match to Java Gel.
More information about Oil Based Gel Stains.
*I Just Watched Your Video on Dry Brushing Gel Stain. Can I Use Ethynol Alcohol Instead of Mineral Spirits to Keep the Brush Discharged During Application?
Yes, but it will evaporate much more quickly so you will need to re-wet the discharge pad more frequently.
See the video below for how to update existing finishes using a dry brush technique.
Can gel stain be used on ceramic tile around a fireplace?
Gel Stain is engineered for wood, but it has successfully adhered to more surfaces than we could have imagined. However, since tile cannot be abraded properly though sanding,  lasting adhesion may be difficult if not impossible.
Milk Paint will have a better chance of adhering than Gel Stain. Dark Chocolate Milk Paint was created to match the color of Java Gel stain, for example. Both products are more likely to adhere if they are applied over a tile-appropriate primer.
Contact a tile store for recommendations regarding a primer that can help finishes stick to ceramic tile.
Even with primer, we cannot give any guarantees that the finish will adhere properly or last. Always test for compatibility between your primer and Milk Paint or Gel Stain before beginning.
If you choose to proceed, test your procedure on a hidden area first and let it cure for 7-10 days. Then further test the finish by duplicating normal wear and tear: washing, scrubbing, scratching, etc. to make sure the finish bonds to the surface.
Can Gel Stain be sealed with wax instead of top coat?
Wax can be used over Gel Stain, if you prefer. Just let the Gel Stain dry 24-48 hours before applying the wax. Note: wax is not a durable product. It needs yearly reapplication, will show daily use (finger marks and smudges) and may be very difficult to remove if a future topcoat application is desired.
*Can Gel Stain Be Used Over Laminate?
GF advises extra care and prep when applying any finish over laminate surfaces because they are specifically designed not to mar and therefore they are not very "sand-able", making adherence difficult.
In addition to this non-permeable surface factor, General Finishes Gel Stain is an oil-based product, and it is more difficult to obtain proper drying characteristics over a dense manufactured surface such as laminate. Gel stains, as all wood stains, were formulated to go over raw wood which has an "open" surface and can absorb some of the stain.
Customers have reported the successful use of Gel products over laminate surfaces. Here are two techniques:
  1. Using Dark Chocolate Milk Paint as a Base under Gel Stain (Dark Chocolate Milk Paint was formulated to mimic the color of Java Gel Stain)
  2. Several techniques using only Gel Stain/no paint or primer
SOME NOTES:
  • If you can abrade the surface by sanding, you will increase your chances of success. If you choose to proceed, test for adhesion on a hidden area of your project before getting started.
  • If you are applying GF Gel Stains over existing "sealed" finished wood or any impenetrable surface, TRIPLE OR QUADRUPLE the drying times of all the finishes used because the stain cannot soak into the surface.
  • De-Glossers: GF does not recommend the use of a de-glosser as a REPLACEMENT for prep sanding and cleaning. They are sold by manufacturers that advocate that it is ok to cover up dirt and grime, which can create a problem. GF feels that appropriate cleaning and sanding delivers a better result and saves money.
  • If you have physical issues with the labor of sanding, at least clean the project before using a de-glosser.
APPLYING GEL STAIN DIRECTLY TO LAMINATE:
  • “Power clean” by scrubbing with a solution of water and a strong detergent such as Dawn or Spic & Span, using a Scotch-Brite pad. Rinse thoroughly.
  • Then follow with a second scrubbing with a 50:50 mix of denatured alcohol and water, also using a Scotch-Brite pad. Let dry completely.
  • Sand with a power sander. 150-grit followed by 180-grit sandpaper. (some users reported using 220 grit sandpaper). Wipe off the dust.
You can apply Java Gel Stain several ways:
  • With a roller for a painted effect (from ABHall), painting on with a chip brush followed by pouncing with a plastic bag for a textured effect.
  • Brushing on followed by a mineral spirit dry-brush technique. See mineral spirits dry-brushing technique in this video
  • Apply a slip-coat of mineral spirits first using a chip brush to give you more open time. While the mineral spirits is still wet, paint the Gel Stain on using a chip brush. While the Gel Stain is still wet, GENTLY smooth out the surface with a folded blue shop towel going in the direction of the grain.
    Tip from Andrea Allred: Dry brush Gray Gel Stain on top the next day for a weathered look.
  • Paint on two coats of Gel Stain, letting each coat dry 72 hours. Create the look of faux wood by sanding each coat lightly.
  • Allow the Gel Stain to DRY 72 HOURS. If it is still tacky and cool to the touch, let it dry for days. Let it dry, let it dry, let it dry. Lack of dry time over existing surfaces is the number one reason for Gel Stain failure!
  • Seal with 3 coats of topcoat, allowing triple dry time. As previously stated, you can use Arm-R-Seal over dark colors and High Performance over light colors.
NOTE: When using fine wood finishes, water and spills must be wiped up in a timely fashion. If this a high-use area near a sink, consider replacing the countertop instead. If this a low-use area such as a bedroom dresser that needs a tune-up, you will be fine.
ADHESION TEST:
Test your entire procedure (preparation to topcoat) on a hidden area first and let it cure for 7-10 days. Then further test the finish by duplicating normal wear and tear: washing, scrubbing, scratching, etc. to make sure the finish bonds to the surface.
See more General Finishes FAQs here.
Should I use a coat of Gel Topcoat on raw wood to achieve an more even color before staining?
While Gel Stain can be applied over an existing finish, it was originally engineered for raw wood surfaces. We prefer applying the Gel Stain over a slip coat of mineral spirits instead of topcoat as shown in this video, "How to Apply Gel Stain to Raw Wood"
The slip coat will reduce the drag and help the stain "glide on" easier. The other important technique shown in this video is to apply the stain liberally in sections and remove the excess quickly. Gel Stain is so pigment rich you will get an uneven application if you try to dab it on with a dry rag.
Applying over a layer of top coat is acceptable, but there are two big benefits of applying the stain directly to the wood or over a slip coat.
  1. The beauty of the grain is highlighted. This effect will be greatly diminished if the stain is applied over an existing finish.
  2. Less coats are required to obtain a dark color.
Preparation and application techniques along with dry time between coats are all different when applying Gel Stain over raw wood vs. an existing finish.
Dry time differences
*What is the Best Topcoat to Use over Gel Stains?
You can use any of our topcoats.
Water-based products include General Finishes High Performance or General Finishes Flat Out Flat.
Oil-based products include General Finishes Gel Topcoat or General Finishes Arm-R-Seal. Gel Topcoat is thick, while Arm-R-Seal is much thinner, and is easier to apply large projects.
Always allow 72-hour dry time when applying water-based products over oil-based products.
Find more information about Oil Based Gel Stains here.
*How Do I Create a Glaze with General Finishes Gel Stain?
Yes - we recommend adding up to 10% mineral spirits. You can add more mineral spirits, but test first. The mixture will thin out quickly. Using more than 10%  can affect the performance and durability of the finish, but as a glaze, this is not as critical an issue because your topcoat will protect the finish.
Can I use GF Dyes Stains under Gel Stains?
Yes, many professional finishers use Dye Stains to increase the depth of the grain, to even out color saturation, and to achieve deeper colors. Use Amber or Yellow for a golden glow under any gel stain.
Can I use denatured alcohol mixed with shellac to condition raw wood before applying Gel Stain?
Yes. Denatured alcohol is the solvent used in Shellac. A 50/50 mix is commonly used when conditioning wood before staining.
*How Do I Match Putty Wood Filler to a Dark Stain?
Putty comes in two forms, pre-colored or as a stainable wood filler designed to fill minor imperfection such as nail holes, cracks, and gouges in the wood surface. Putty will display stain a bit differently than wood, so it is not a "perfect" fix, but a good one.
The goal is to get the best possible color match to either the color of the raw wood or the color of your existing finish.
The easiest route is to buy a putty that is pre-mixed with color. Both Famowood and Timbermate make colors of putty in several shades. Famowood is available in both oil-based and water-based formulas. Timbermate is an interior grade water-based filler and comes in 13 pre-mixed colors.
Be careful to note if you are buying a solvent (oil) based putty or a water-based putty. Either will work as long as you observe opposing dry times when switching as you would do for finishes.
DRY TIMES:
  • Water over oil: a minimum of 72 hours
  • Oil over water: a minimum of 24 hours
If you cannot purchase the right color match, you can tint the putty with stain to create a custom color. For example:
TO USE:
  • Prep sand your piece. If you are using with an existing finish, thoroughly prep clean and scuff sand your project first.
  • Press wood filler into defected area.
  • When dry, sand flush with surrounding surfaces after approximately 15-30 minutes, depending on temperature, depth of fill and whether the putty is oil or water based.
Finally, another good putty is Color Putty. They make both water and oil-based versions in ready-made colors. This is a soft putty that can be used AFTER the project is finished to fill nail holes or small imperfections.
ALWAYS TEST filler, stain and finish combinations on a small area before applying to your project.
SOME NOTES:
ADHESION TEST:
*Can I Use Interior Wood Stains Outdoors If I Coat With an Exterior Topcoat?
Watch Exterior 450 Topcoat product overview video
Watch Exterior 450 Stain product overview video
*How Can I Get Stain and Topcoat to Adhere to Knots on Pine? When I Apply the Topcoat, the Stain Starts Pulling Off.
Uneven Gel Stain on Knotty Pine
Pine is full of pitch (rosin or tar) and stain alone will never adhere to these areas. The knots are so dense and hard there is no grain to hold the stain in place
To fix, sand the table lightly with 120-grit sandpaper and restain the table. To improve adherence of the stain, mix 2 parts Gel Stain with one part Gel Satin Topcoat. Apply as many coats of the mix as needed to obtain the desired color, allowing 24-hour dry time between coats.
Note: The stain may never adhere well to the knots because they are too dense to hold a stain. You can try dry brushing the knots with the stain to deepen the color and the protect with topcoat.
Note: Pine knots will always continue to bleed through a light paint. You must incorporate the knots as part of the finish design.
*How Do I Correct the Haze That Appeared When I Applied Gel Satin Topcoat Over 3 Coats of Gel Stain?*
Haze (the technical term is blush) is caused by too many coats applied too quickly. A recoat time of 12 hours is not enough dry time when applying over an EXISTING finish. To remove the blush or haze, you can either wipe the area with a strong solvent, like xylene or lacquer thinner, or you can try sanding out the haze and then reapply the topcoat.
Always allow more dry time when applying oil-based products over an existing finish. Here are General Finishes recommended dry times for applying multiple coats of Gel Stain and Gel Topcoat over an existing finish.
  • Dry-Time to Touch: 4-6 hours
  • Dry-Time to Recoat with Stain When "Wiping Off": 72 hours. Do not recoat until you are sure the stain is dry. If in doubt, wait longer. Humidity or cold temperatures will increase dry times.
  • Dry-Time to Recoat with Stain When "Painting On": 72 hours. Do not recoat until you are SURE the stain is dry. If in doubt, wait longer. Humidity or cold temperatures will increase dry times.
  • Dry-Time to Apply Oil-Based Topcoat over Gel Stain: 72 hours
  • Dry-Time to Apply Water-Based Topcoat: 72 hours
  • Dry-Time for Light Use: 7-10 days
  • Dry-Time Over Laminate or Other Non-Porous Surfaces: At least 72 hours, likely more. Test to your satisfaction before proceeding.
  • CURE TIME: Cure time for all General Finishes oil-based products is about 30 days. During the curing process, protect your flat surfaces and avoid placing heavy items on horizontal surfaces or sliding anything across the surface.
Dry time and cure time are unrelated. In simplest terms, here is the difference between drying and curing: Drying is the evaporation of solvents in oil-based products, and water in water-based products. Curing is when the product hardens for full use.
*Is Topcoat Required Between Gel Stain and Water Based Glaze Effects?
Yes - this is not a good place to take shortcuts. GF Gel Stain gets its deep rich hue from a large number of colorants. Seal the stain with a topcoat before applying glaze to prevent "color pull."
The glaze will also glide more easily over the surface after topcoat is applied, allowing you greater control of how much color you want to use. Be sure to wait 72 hours when applying water-based finishes over oil-based finishes.
Here is a sample finish schedule:
  1. Prep sand and clean
  2. Apply stain
  3. Apply a layer of topcoat to prevent color bleed thru and make glazing easier
  4. Apply Glaze Effects
  5. Apply 2-3 coats of topcoat to protect the entire project
