Arm-R-Seal Urethane Wipe-On Topcoat
Arm-R-Seal Oil-Based Topcoats are made with the highest-quality urethane resin, making them extremely durable and long-lasting. Formulated to be wiped on with a cloth or applied with a foam brush, this ambering finish penetrates to provide deep-down protection for that "natural" look. Arm-R-Seal is a PFAS-free topcoat, and as General Finishes strives for a cleaner and healthier environment, all future product development will be free of “Forever Chemicals." Need some inspiration? Visit the General Finishes Design Center or Pinterest Board.
General Finishes Satin Arm-R-Seal Oil Based Topcoat, Quart
RAW WOOD:
1. Sand up to 150-grit sandpaper.
New Stained Surface: Do not sand. Apply directly to stained surface.
SEALED SURFACE:
See our video: How To Prep an Existing Finish
2. Dry 1-2 hours.
3. Sand lightly with 220-320-grit sanding sponge.
4. Remove dust with a vacuum, compressed air, a tack cloth or a water-dampened rag.
Step 2: How To Apply General Finishes Arm-R-Seal
General Finishes Arm-R-Seal Oil Based Topcoat Application Steps
Watch our video: How to Apply Arm-R-Seal
  2. Do not apply over light or white finishes as this is an oil-based finish, which is amber in color upon application and will deepen over time. Use over raw wood or dark paints.
  3. Stir the wood finish thoroughly and often throughout use to reincorporate solids that have settled to the bottom of the can. Alternately, stir well and immediately decant what you'll be using. Arm-R-Seal is a thin urethane topcoat; the flatting agents used to create flatter sheens quickly settle to the bottom of the can and need to be redistributed often.
  4. Test for adhesion when applying over a sealed surface.
  5. Arm-R-Seal rarely needs thinning due to its low viscosity. If desired, thin with up to 10% mineral spirits unless restricted by local or state regulations.
  6. Apply 3 coats. No more than 3 coats is recommended. Additional coats will not improve durability.
    • Hand application: Apply a liberal amount of product using a cotton cloth, foam brush or staining pad with smooth, even strokes & light lap lines. The larger the surface the large the applicator needed. Wipe off the excess evenly with the grain & with light pressure using a cloth or high-quality absorbent paper towel. Avoid heavy pressure & back-brushing. It is more important to avoid over brushing when using Satin Arm-R-Seal, because of the increased flatting agents needed to create a SATIN sheen. Semi-gloss and Gloss sheens are easier to apply because there are little to no flatting agents.
    • Spray application: Arm-R-Seal can be sprayed successfully, but we prefer hand-application methods because it is easy to spray too much in one area. Spray thin coats and immediately wipe or brush out runs if they occur. Spray wet films at 3-5-mil thickness. HVLP: 1.0mm-1.2mm spray tip, medium air cap. Verify tip sizes with your equipment supplier. Click here for a general guide to spray tip sizes. Keep your gun at a 90° angle, 6-8" from the surface. On large, flat areas use wet, even patterns 6-8" wide. For narrow surfaces, reduce the fan pattern to 2-3" wide to reduce overspray. Overlap each pass 10% to conceal lines. Wear a full filter NIOSH/MSHA-approved respiratory & eye protection and work in a well-ventilated space. Read here for more information on spraying techniques.
  7. Finish sand between coats with a 320 grit or finer sanding sponge or '0000' steel wool to improve smoothness and adhesion.
  8. Remove dust with a vacuum, compressed air, a tack cloth or a water-dampened rag.
Tips to Prevent Streaking
  1. Choose a semi-gloss or gloss sheen with little to no flatting agents. The more flatting agents, the more likely a topcoat will streak when applied.
  2. Optionally, if you want a flatter sheen, put down 2 coats of semi-gloss, followed by satin.
  3. Either stir and decant what you need to use immediately or stir frequently throughout the application process. Urethane topcoats are thin and the flatting agents used to create flatter sheens settle quickly to the bottom of the can.
  4. When working with a satin sheen, apply a liberal amount of product, and avoid pressure and back-brushing. Wipe along the wood grain using smooth, even strokes.
  5. Remove streaks that occur by buffing with 0000 steel wool or a fine-grade (220-320) foam sanding pad. You can also sand well and re-coat.
Compatibility With Long Oils
Arm-R-Seal can be used over Danish Oil, Linseed Oil & Tung Oil after they are dry. Allow oil to dry overnight before applying GF product.
Dry Time Between Coats
Dry 12-24+ hours between coats when applying over raw or newly stained raw wood, and dry up 72+ hours between coats when working over a sealed surface. Dry times based on ideal conditions: 70°F/21°C; 50% humidity. The more layers of finish there are on a project, the longer it takes to dry. Do NOT rush the dry times!
Inadequate dry time can trap moisture & cause clouding.
  • Cooler temperatures
  • To accelerate dry time in humid conditions, work in a space with good ventilation and air movement. If you decide to re-coat before the recommended time, test dryness.
Cure Time Before Use
Oil-based finishes cure and harden completely after 30 days. Avoid placing heavy objects on surfaces that have not completely cured. Treat gently, and do not clean with commercial products during the cure period.
Storage of Oil Based Products
Arm-R-Seal Warnings and Warranties
  • Gloss: No chemicals were found in this product which are known to the State of California to cause cancer, birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov.
  • Satin & Semi-Gloss: This product can expose you to Benzene, which is known to the State of California to cause cancer and birth defects or other reproductive harm. This product can expose you to chemicals including Crystalline silica, respirable powder, which is known to the State of California to cause cancer, and Toluene, which is known to the State of California to cause birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov.
DANGER COMBUSTIBLE LIQUID AND VAPOR. HARMFUL OR FATAL IF SWALLOWED.
CAUSES EYE IRRITATION.
DANGER: Can enter lungs and cause damage.
DANGER: Keep out of reach of children. Keep away from heat and flame. Use only with adequate ventilation. Do not breathe vapor or mist. Do not swallow. Avoid contact with eyes. Keep container tightly closed when not in use. Wash thoroughly after handling.
Product Colors Dries Amber
Ambering Yes
Sheen Satin (25-35), Semi-Gloss (50-60), Gloss (80+)
Tintable No
Type Urethane
Application Method Brush, Roll
Spray Tip Sizes HVLP 1.0mm-1.2mm
Dry Time - Touch 12+ hr
Dry Time - Recoat 24+ hr
Dry Time - Cure 30 days
Coverage 50-60 sq.ft./pint, 100-125 sq.ft./quart, 400-500 sq.ft./gallon
Viscosity Thin
Viscosity (cPs) 100-200
Weight Solids 32%
Gloss: < 528 g/L
Satin: < 576.788 g/L
Semi-Gloss: < 575 g/L
Durability (Highest, High, Medium, Low) Highest
Hardness (Koenig #) 77
Wear (Taber #) 57.10 mg loss
Chemical (105 max) 99
Arm-R-Seal FAQs
*Can I Spray Arm-R-Seal?
Arm-R-Seal can be sprayed successfully, but we prefer hand application methods because it is very easy to spray too much in one area. If you choose to spray, use very thin coats and watch for runs (large drips that run down the side of your project).
If you notice a run, immediately wipe or brush it out. If you correct a run promptly, you will not see a mark. However, dried runs can be difficult to remove.
Wear a mask and work in a well-ventilated spray booth.
Size: Small Needle Nozzle (1mm)
*Can An Oil Based Topcoat Such as Arm-R-Seal Be Thinned?
Although Arm-R-Seal rarely needs thinning because of its low viscosity, it can be thinned with up to 10% mineral spirits - more than that may thin the solids content too much.
Thinned Arm-R-Seal will be diluted but can be stored without risk of separation.
*Can I Change the Sheen of the Topcoat? The One I Applied Is Too Shiny.
If you want to change the sheen, you can re-coat with a different sheen over top. The second layer of top coat will replace the appearance of the first.
Sand lightly with a used 220 sanding PAD to knock down the original finish before re-coating. It may take two or 3 coats to get complete coverage.
*What Finish Would You Recommend for a Butcher Block Counter Top?
It depends on the type of use you plan for your butcher-block top and the look you want.
If it is a statement piece and not intended for high use, almost any finish would work. General Finishes Arm-R-Seal Topcoat is a good choice. If you intend to prep or chop food General Finishes Butcher Block Oil should be applied.
However, neither product will withstand continuous water use or standing water, or hold up to knife cuts. We always use a cutting board just as we would on a standard kitchen counter. Basically, all horizontal wood surfaces in a kitchen must be maintained, and will easily wear with high water use.
Differences:
  • Butcher Block Oil is a maintenance product that should be reapplied over time. It has a lovely matte finish that soaks into the wood and is an excellent protectant for wood surfaces that come in contact with food. Simply wipe on, allow 5 minutes to penetrate and wipe off the excess. It can also be used on cutting boards, utensils, or bowls. It is one of our most popular finishes for butcher-block counters.
  • Arm-R-Seal is a fine furniture finish, offers several levels of sheen and is a durable finish. It has been successfully used on home bar projects with this caveat: no fine furniture finish is impervious to water. Spills must be wiped up in a timely manner.
For a more water-resistant finish, we recommend visiting a finish dealer that carries lines specifically designed for high water use such as an Epoxy or a professional two-step catalyzed finish such as General Finishes Conversion Varnish.
*Why is Arm-R-Seal Blotching Over an Oil Based Stain on a Table I am Refinishing?
The problem areas on your table are probably caused by surface contamination from oils, waxes or cleaning products used over the years.
Contaminants from dusting sprays that contain silicone will also impact the appearance and adherence of a finish - silicone is almost impossible to remove. Oil soaps and wax can also cause adhesion failures. This may be why the finish is performing differently on the leaves vs the table top. Adhesion failure is often more obvious in the deepest patterns of grain because the contamination is driven deep into the grain.
Unfortunately, even though you sanded the table down to raw wood, sanding alone will not remove this type of contamination. In fact, sometimes the friction heat of sanding will drive contaminants deeper into the grain.
You have two options, and we recommend the first:
  1. Strip, sand and refinish the table. Use a strong solvent such as a paint stripper and, brushing the surface with a soft brass brush to clean out the grain. Follow this by cleaning with 0000 Medium steel wool and mineral spirits.
  2. Buff the existing finish with 0000 steel wool and mineral spirits, particularly in the affected areas, and then re-apply several more coats of Arm-R-Seal
*Is it safe to buff Arm-R-Seal with an auto polish?
We know of many customers that have achieved great results from buffing Arm-R-Seal with auto polishes, providing that the finish has cured for 7 to 10 days.
As with all products that are not manufactured by General Finishes, always test for compatibility on a hidden area of your project before getting started.
*Why did my remaining Arm-R-seal thicken in the can?
Oil-based topcoats are "oxidizing" products which means that the moment it is introduced to oxygen, a chemical reaction will cause the finish to begin to harden. As topcoat is used, the empty space in the can is filled with air, furthering the curing process.
Tips to ensure your Arm-R-Seal remains in great working condition:
  1. Decant the amount of Arm-R-Seal you will need into a foil covered bowl or paper cup and reseal the can right away. Every minute the can is open, the stain is curing.
  2. Be sure to thoroughly clean the chime and the lid of the can to assure a tight seal.
  3. Add Bloxygen to remove excess oxygen from your can of finish before sealing.
  4. Store your sealed cans upside down. The liquid creates a seal around the lid when stored upside down, preventing air from getting in.
  5. Transfer any unused finish to a smaller container once finished with your project. StopLoss Bags® are a popular choice.
*Which General Finishes Products Would Work Best on a Restaurant Table?
GF has two products that would work well.
For non-professional finishers, we recommend using General Finishes Arm-R-Seal Topcoat.
Arm-R-Seal is oil based and will amber. Be sure to apply liberally with a foam brush or roller, letting the product self-level a bit. A liberal application will help you avoid streaks caused by back-brushing and pressure. Stir product thoroughly before and during application because flatting agents settle quickly in a solvent base finish.
For experienced professional finishers who spray, we recommend our two-step General Finishes Conversion Varnish, which would cure in half the time and dries clear.
Even though General Finishes products are water resistant, they are not impervious to standing water condensation (like an epoxy finish). As with any fine furniture finish, spills should be wiped up in a timely manner. We recommend using coasters to protect your wood from water condensation and pot holders to protect from heat.
Differences:
*What Topcoat Should I Use on Padauk Wood?
Padauk Exotic Wood
We recommend an oil-based finish such as General Finishes Arm-R-Seal.
Oily woods can be tricky with any topcoat. The high oil content affects the drying process of the finish coats and Padauk has a very high oil content. Sometimes oily woods dry fine and sometimes they take weeks.
Try wiping the wood with alcohol or acetone to dry the oils before coating. This technique may help but does not work all of the time - each piece of wood is different.
To be safe, always plan on a long dry time.
*Why Does My Oil Finish Have a Haze When Applying Arm-R-Seal Over a Linseed Oil Based Stain?*
Linseed oil stains take a LONG time to dry. When applied too soon, Arm-R-Seal will likely prevent the linseed oil-based stain from gassing out and drying completely due to solvent entrapment, causing a haze.
  • Enduro Professional Pro Series Clear Poly
  • Enduro Professional Pro Series White Poly
  • High Performance Topcoat
  • Flat Out Flat Topcoat
  • Enduro-Var II Topcoat
  • Exterior 450 Topcoat
  • Wood Turners Finish
  • Exterior 450 White
  • Arm-R-Seal
  • Seal-A-Cell
  • Gel Satin Topcoat
  • Wood Bowl Finish
  • Butcher Block Oil
  • Outdoor Oil
  • Hard Wax Oil
GENERAL PRACTICE:
  1. Oil-based topcoats and ENDURO-VAR II will amber over time.
Compare all topcoats
