High Performance Water Based Topcoat from General Finishes
Winner of Fine Woodworking's Best Overall Choice Award, High Performance Topcoat was voted as the hardest, most durable consumer polyurethane topcoat.
Need some inspiration? Visit the General Finishes Design Center or Pinterest Board for furniture topcoat ideas.
Features
Winner of Fine Woodworking's Best Overall Choice Award, High Performance Top Coat is the hardest, most durable consumer polyurethane top coat on the market today.
It contains a UV Stabilizer to retard the finish from breaking down in sunlight. And with its pure polyurethane durability, it can even be used on floors. This is the most durable product.
Colors: Water White (dries clear). Note: Water topcoats can pull tannins, stains and dyes from surfaces that are not properly prepped.
Sheens: Flat, satin, semi-gloss, gloss
Recoat/Dry Time: 2-3 hours
Number of coats: 3-4
Dry time for light use: 7 days. Good ventilation, air movement and higher temperatures will accelerate cure time. Cooler temperatures will slow cure time.
Cure time: Light use (7-10 days), Regular use (21 days) under ideal conditions (70 degrees and 70% humidity)Good ventilation, air movement and higher temperatures will accelerate dry time. Cooler temperatures will slow cure time. Cure time is the amount of time needed for the finish on a piece to reach maximum hardness and be ready for normal use. This is different than "dry time."  This is different than "dry time." During the curing stage, treat your project with special care. Avoid placing heavy objects on it. Always avoid the use furniture polishes, dusting sprays or oil soaps as they may contaminate the finish for future recoating. Use a water dampened cloth for regular cleaning.
Water Spills and Daily Use: Clean water spills up as they occur during regular use and protect from heat. Although General Finishes products are water resistant, they are not impervious to water. Surfaces will not be damaged by spilled water so long as it is cleaned up promptly. We recommend using coasters to protect your wood from standing water and pot holders to protect from heat.
Cleaning your finish: Clean with a water-damp rag. Do not clean until the finish has cured completely (21 days).  If your surface requires deep cleaning due to grease or grime, add a speck of detergent or a bit of vinegar. Avoid using oil-soap or silcone-based daily cleaners such as Pledge, Endust or Murphy's Oil.
Applicator Cleanup: Warm, soapy water. For best results, clean all equipment with General Finishes Brush and Gun Cleaner.
Coverage: 150 sq ft/qt
Can Sizes: Pint, Quart, Gallon
Sheens: Flat, Satin, Semi-Gloss, Gloss
Recommended Use: Interior use only, Wood applications
Topcoat Recommendation: High Performance is self sealing and can be used alone, but it can also be used with GFs Sanding Sealer
VOC: < 275g/l (2.25 lb/gal)
WARNING: TEST FOR COMPATIBILITY WHEN USING THIS PRODUCT WITH PRODUCTS FROM OTHER BRANDS.
General Finishes products should be tested to your complete satisfaction before using. General Finishes will not be responsible for any failure if our products are used in conjunction with other brands of finishes. We do not test General Finishes products with those of another manufacturer and will not accept liability if there is a compatibility issue.
Reviews
High Performance Polyurethane Water Based Top Coat Review 12/16/2010
5 years 37 weeks ago
By far the best finish for my projects that I have found in 50 years of woodworking. On kitchen table, this is the only product that stood up to the wear and normal use conditions.
Use of EF extender is a good idea in summer: higher heat/low humidity accelerate the drying too fast leaving brush stokes. With extender, and/or higher humidity, the finish levels out well.
High Performance Polyurethane Water Based Top Coat Review 02/06/2011
5 years 29 weeks ago
I used the High Performance Polyurethane for the first time on an entertainment center I made. I was very happy with the application process. It seems to be marginally thicker than the other popular water based poly which I have used in the past. I had no problems with dripping, sagging on vertical surfaces and small bubbles (foaming) forming on edges and at joints which I have had with the other poly. More expensive but well worth it.
High Performance Polyurethane Water Based Top Coat Review 02/11/2011
5 years 28 weeks ago
I used the High Performance Poly on a recent project and was absolutely thrilled with it's application. I have used the other popular water based product in the past with trouble with sagging on vertical surfaces and small bubbles on edges and where surfaces come together. I had none of those problems with High Performance Poly. It is well worth the higher price.
